#1 |
Member#: 114225
Cusco website says their LSD wont work with ABS equipped subaru vehicles.
For people who has Cusco LSD, did you guys disable your ABS? I wonder what's wrong with Subaru's ABS system. Other companies, they do not have a note on ABS. Go to cusco.co.jp/05_ctg/5lsd_pdf/lsd_134.pdf Thanks!
#2 |
Member#: 80430
Vehicle:1997 Eagle Talon (plus a Legacy beater) |
Your ABS might be of the 2-channel, corner-to-corner type, which assumes a 50/50 center split to work correctly.
Oddly enough, the ABS in Mitsubishis (at least up to Evo7 and including all DSMs) is of the 3-channel, rear-select-low type, so we can use any center diff that we wish. - Jtoby |
#3 |
Member#: 114225
My subaru has 4-channel/4-sensor/4-wheel. Is that why causing problems?
#4 |
Member#: 80430
Normally a true 4-channel doesn't care about the diffs because it only pulses the wheel that is locking. Are you sure it's a 4-channel?
- Jtoby |
#5 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
| Thread Tools | |
| Display Modes | |
| 92 Mazda Miata 5 speed, black on tan LSD, ABS, Loaded | nissanguy8 | Private Vehicle 'For Sale' Classifieds | 0 | 07-08-2006 12:59 AM |
| turbo xs problem on my abs | wrxzo6 | Factory 2.0L Turbo Powertrain | 10 | 11-16-2005 11:23 AM |
| Anyone found a solution to ABS problem? | vapore0n | Brakes, Steering & Suspension | 10 | 12-19-2002 03:27 PM |
| Thoughts and Log on WRX ABS Problem | ScrappyWRX | Warranty Issues & SOA Problems | 4 | 07-02-2002 05:57 PM |
| Anyone have problems with their abs brakes on rs. need input! | wrxman555 | General Forum Archive | 2 | 10-24-2000 05:15 PM |
