Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 05-25-2006, 11:47 AM   #1
Ging
Member#: 3258
2000 Impreza TS
Default Where to get Struts?
I just got a call from my mechanic and they told me that 3 out of the 4 struts are toast. So it is time for some new struts and springs.... finally! Been waiting for this day :P
I've got a 2000 TS and was thinking of KYB AGX + some springs for a 1" drop?
Any recomendations on what and where I should go to get them. I'd much rather buy within Canada.
Thanks!
C
Ging is offline   Reply With Quote
Old 05-25-2006, 11:50 AM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I'd pair the AGX with Eibach springs if you want a slightly more aggressive than stock look/ride. I'm using H&R with mine and that's nice too though lower than 1". As for where...there are probably some local shops in Calgary that can source them no? Otherwise try ordering from Rocket Rally here in BC, I'm sure they'll be able to get them for you.
Keiho is offline   Reply With Quote
Old 05-25-2006, 12:13 PM   #3
Ging
Member#: 3258
2000 Impreza TS
I was just hoping to get suggestions on shops before I make all those phone calls I'll check out the AGX Eibach combo.
Old 05-25-2006, 12:51 PM   #4
Ging
Member#: 3258
2000 Impreza TS
Am I going to need mounts and boots to go with the AGXs?
Old 05-25-2006, 01:01 PM   #5
klug
Member#: 4133
'01 2.5RS Sedan
'05 LGT Wagon
Ging,
If you don't need the adjustability, go with the GR-2's. Cheaper. I'm running those with Eibach springs and it works well. Use your stock bump stops and bellows. IIRC, you may need to cut down the bump stop by a third.
Best local price I found was at Gregg Distributors. Good Luck.
klug
klug is offline   Reply With Quote
Old 05-25-2006, 01:16 PM   #6
vincent-h
Member#: 59504
2005 Impreza RS
have u looked into megan coilovers for the price its almost equally as good as a spring/strut combo if not better
vincent-h is offline   Reply With Quote
Old 05-25-2006, 02:27 PM   #7
Ging
Member#: 3258
2000 Impreza TS
Grap! No AGXs in the City. :P I must widen my search I guess.
Got my prodrive springs installed.... where to get KYB AGX struts? tacomaprime Brakes, Steering & Suspension 10 03-14-2005 10:46 PM
Shocks and struts, where to get them? mr_disco Newbies & FAQs 3 10-10-2004 09:41 AM
Where to get strut install done in houston? IwantONE Texas Impreza Club Forum -- TXIC 4 08-22-2004 09:46 PM
Where to get STI strut tower bars? Chocobo Brakes, Steering & Suspension 3 02-20-2002 04:28 PM
Where to get bushings and strut top mounts for new WRX? jmott Brakes, Steering & Suspension 1 06-13-2001 07:30 PM
