Old 10-11-2001, 05:09 PM   #1
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Default Idle Air Valve Question
Where should this be hooked up, before or after the turbo. I have mine hooked up before the turbo and i think it is returning the boost back to the intake, like a BOV. Would there be any problems hooking it up to the pressure side of the intake.
Scoobie Steve is offline   Reply With Quote
Old 10-12-2001, 01:57 AM   #2
kaos200
Member#: 2692
What??
Do you mean the Idle air control valve? (IAC)
Why are you installing another one?
they are supposed to go from the "boosted" side. To the intake manifold AFTER the TB.
kaos200 is offline   Reply With Quote
Old 10-12-2001, 04:28 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i am lost as to why he is even playing with his IAC(Idle Air Control)
Jeremy
Old 10-12-2001, 04:52 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I'm kinda lost also...
Eric
Eric SS is offline   Reply With Quote
Old 10-12-2001, 07:42 PM   #5
Scoobie Steve
Member#: 2289
Sorry to confuse, i should have mentioned it is a 2.2l, it has a IAC valve on the side of the intake(not the TB). In stock form a 1/2 hose ran from the intake piping to the IAC Valve. Now that the car is turboed i wanted to know where i should hook it up, Before or after the turbo?
Old 10-12-2001, 07:51 PM   #6
kaos200
Member#: 2692
after, or else if you put it preturbo, when the turbo is sucking air, it would also be taking (trying to atleast) air from the valve, and that could cause leakage problems
Old 10-12-2001, 10:15 PM   #7
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default IAC hookup
Hi Scoobie.
I think you mean where do you connect the inlet 1/2" hose for the IAC, correct? If this is the case , fabricate a filtered air source after the air cleaner and before the turbo inlet. There is likely already is such an outlet if you use the standard aftermarket intakes available. This is the source of air for idling and starting, so you don't want boost pressure into the IAC. Does this answer the question?
Mike McBride
MZM is offline   Reply With Quote
Old 10-12-2001, 10:50 PM   #8
kaos200
Member#: 2692
Default Re: IAC hookup
Originally posted by MZM
Hi Scoobie.
Mike McBride
WOW you get boost pressure at idle and starting, damn how small is that turbo!@!?
Old 10-13-2001, 03:15 AM   #9
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Comedian
kaos200 WOW you get boost pressure at idle and starting, damn how small is that turbo!@!?
Kaos you are a funny guy. In the interest of imperical scientific evaluation, plug your IAC inlet on the boost side of your turbo and report back about what happened.
MM
Old 10-13-2001, 03:57 AM   #10
kaos200
Member#: 2692
Default Re: Comedian
MM
hehe, already did. Ran normal, Idled normal, started normal
Idle air valve wiring Racebug1098 Electrical & Lighting 0 02-01-2010 01:44 PM
PCV and idle air control valve operation questions UKscooby Off-Topic 43 07-20-2009 06:46 PM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 12:37 PM
Which one is the Idle Air Valve? whtlegacy Normally Aspirated Powertrain 2 08-06-2003 07:26 PM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 08:45 AM
