Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-11-2001, 05:03 PM   #1
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Default Where to tap for oil psi gauge?
Well, where should I tap it off of? the Turbo oil feed line, or somewhere else? Its an electrical Autometer gauge
STiShawn is offline   Reply With Quote
Old 10-11-2001, 05:15 PM   #2
Nat
Member#: 759
2004 WRX
2000 SV650
Nat is offline   Reply With Quote
Old 10-11-2001, 05:28 PM   #3
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
You could tee off right where the stock pressure sender is mounted. You have to take off the alternator to get at it, though.
the Dabbler is offline   Reply With Quote
Old 10-11-2001, 06:11 PM   #4
Delicious Tuning
Member#: 1990
Take a look at the second picture down on this page. Look for number 3 circled in red. Right above that is where I put my Oil Pressure Sendor.
That location is on the passenger side right below the throttle body and intake manifold.
If you already have a line coming out of there for the Turbo you can just "T" off of that.
I guess that would be your Turbo Oil Feed line. I also have a Electrical Autometer Guage as one can see...
Delicious Tuning is offline   Reply With Quote
Old 10-11-2001, 11:56 PM   #5
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Nat, can you please E-mail me that info also? I have the same question. Thanks, [email protected]>COM
LVSUBARU is offline   Reply With Quote
Old 10-12-2001, 09:18 AM   #6
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
NAT, e-mailed you...thanks guys..non of you know how to wire an ITC do you?
Old 10-12-2001, 11:19 AM   #7
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
The picture in the thread on where to tap for a boost guage also shows where the oil line comes off the block. This is what The Dabbler was refering to.
http://i-club.com/forums/showthread....threadid=99123
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-12-2001, 02:44 PM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
thanks
Where to tap for oil pressure gauge? joltdudeuc Normally Aspirated Powertrain 9 04-11-2006 09:46 PM
where to tap for mech. boost gauge monzon Electrical & Lighting 6 12-17-2005 07:17 AM
Where to Tap for Boost Gauge Dimmer? USF97J4x4 Electrical & Lighting 10 11-30-2005 11:04 AM
Where to tap for positive gauge wire? xq89olp Electrical & Lighting 5 07-05-2005 08:54 PM
Where to tap for Turbo Oil inlet. Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-17-2003 07:53 PM
