Old 10-11-2001, 05:20 PM   #1
fastline
Vendor
Member#: 9224
2004 STI
12.88@ 106.2 in my WRX
Default fuel cut defender?
anyone make a home made fuel cut defender for a 02 WRX yet and if so how can i do it?
thanks for any info
fastline is offline   Reply With Quote
Old 10-11-2001, 06:14 PM   #2
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Please explain to me would you want to have it?
Imprezer is offline   Reply With Quote
Old 10-11-2001, 06:24 PM   #3
fastline
Vendor
Member#: 9224
2004 STI
why i would want it?
to run more boost in the future when other mods are complete.
need to run more than 16lbs someday
Old 10-11-2001, 06:27 PM   #4
JenisonWRX
Member#: 6049
02 WRX & 99 RS
You can do that now...
Its the ecu you need to adjust. If you threw in a MBC/EBC right now...you could run 16 lbs...
If you want to run more then that...then you need more mods
JenisonWRX is offline   Reply With Quote
Old 10-11-2001, 06:35 PM   #5
fastline
Vendor
Member#: 9224
2004 STI
the question is "anyone make a home made fuel cut defender for a 02 WRX yet and if so how can i do it? "
i know i can't run more that 16 or so lbs of boost with a stock car with out hurting something
fuel cut hits at 16lbs or something close to that and it will always be there unless you fool the ECU...... "anyone make a home made fuel cut defender for a 02 WRX yet and if so how can i do it? "
more mods are good but what is the sense if you put a big turbo on, bigger fuel pump, bigger injectors and so on if you can't turn the boost up....it will still hit fuel cut unless you change it.
Old 10-11-2001, 07:52 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
These threads touch on the subject, particularly the posts by TurboXS:
http://www.i-club.com/forums/showthr...threadid=40783
http://www.i-club.com/forums/showthr...threadid=39938
Jon [in CT] is offline   Reply With Quote
HKS fuel cut defender?? are you using it? trboCIVIC&WRX Factory 2.0L Turbo Powertrain 11 08-07-2003 08:09 PM
looking for hds fuel cut defender wiring diagram boogerwrx Southern California Impreza Club Forum -- SCIC 2 07-14-2002 12:43 AM
looking for hks fuel cut defender wiring diagram boogerwrx Factory 2.0L Turbo Powertrain 0 07-13-2002 11:16 PM
fuel cut defender dub976 Factory 2.0L Turbo Powertrain 2 05-16-2002 08:07 PM
Fuel cut defender BleuWRX Factory 2.0L Turbo Powertrain 0 10-31-2001 12:42 AM
Message Board Statistics All times are GMT -4. The time now is 01:59 PM.
