Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-26-2006, 10:52 AM   #1
baldchicken
Member#: 92670
03 WRX
Default UTEC log issues, need help!
My UTEC all of a sudden logs in this format....
;56H1.5OFF 00 2.0 --- OFF  1986 0+21.6 85 3.3 16-10.61.6-02.8 0013.5 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.5OFF 00 2.0 --- OFF  1985 0+21.5 85 3.3 17-10.61.7-02.4 0013.7 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.5OFF 00 2.0 --- OFF  1981 0+21.6 85 4.8 17-10.61.7-02.6 0013.6 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.3OFF 00 2.0 --- OFF  1943 0+18.3 85 2.8 17-10.81.4-04.6 0012.9 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.3OFF 00 2.0 --- OFF  1833 0+15.0 85 3.8 16-11.41.4-05.9 0012.5 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.3OFF 00 2.0 --- OFF  1623 0+12.5 85 3.8 17-11.81.4-01.0 0014.2 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.3OFF 00 2.0 --- OFF  1395 0+12.9 85 3.8 16-12.41.4+08.2 0021.9 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 1.3OFF 00 2.0 --- OFF  1213 0+21.0 85 23.8 17-12.41.4+09.4 0023.4 to 1 OFFMAP 1  1ECU.  +0.0 ECU. 2.3OFF 00 2.0 --- OFF  1484 25 +2.8 86 5.8 ...
Started happening about 2 weeks ago. I am at the dashboard and go to transfer -> capture... then I stop it when I am done. Has anyone seen this before? Any suggestions?
Thanks!
baldchicken is offline   Reply With Quote
Old 05-26-2006, 11:07 PM   #2
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
This is what you get in dashboard mode...you cant simply "log" dashboard mode in hyperterminal. Those funny numbers are coordinates for where to draw the related data.
Try using Logger-1 instead. If you want to also log Air temps and coolant temps you can use UTI, my program. It can log in dashboard mode just fine.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 05-30-2006, 12:23 PM   #3
baldchicken
Member#: 92670
03 WRX
Hmmm... I used to be in dashboard mode, and I could go to Transfer -> capture... and I could export it to a text file and it used to come out just fine. Now it doesnt. So you suggest using logger instead of the capture mode?
Old 05-30-2006, 12:26 PM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
No he suggests using the number 1 logger instead of dashboard. You cannot capture text from the dashboard. I think you were using the #1 logger before but didn't realise it.
cdvma is offline   Reply With Quote
Old 05-30-2006, 04:58 PM   #5
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
yea, at the main screen just press "1" then the capture....or you could just use UTI and have it auto-log for you, as well as shift alert, overboost alert, fill in tables on the fly, show horsepower/tq, save knock incidents, etc. etc.
Jeff
09 WRX Hesitation - Logs Inside - Need Help Suby Noob AccessPort 6 08-03-2009 12:09 AM
UTEC tuning issues need help asap Sharky NRK Engine Management & Tuning 6 11-11-2005 05:23 PM
Electrical Issues Need Help! mRgUnN Electrical & Lighting 8 05-20-2003 04:31 AM
Boost Issues, Need Help kdawg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-08-2002 03:25 PM
