Old 10-11-2001, 06:15 PM   #1
wrx182
Member#: 9531
2002 WRX Sport Wagon
Default where is the ebrake wire that i splice with the gray wire from my turbo timer???
i've got the hks type 1 and i need to know what wire, and where, to cut the gray wire into for the ebrake....thank you much
also, when i am modding the timer to work with the security system, do i just cut the dark green wire with the black trace and the gray wire coming from the security box by the brake? thats all? just cut them in half and leave them? or do i have to rewire them to somwhere else?
thanks
wrx182 is offline   Reply With Quote
Old 10-11-2001, 06:29 PM   #2
joefong
Member#: 6611
02 WRX
Its the blue one
the ebrake wire is the pink one. u need to take off the center console and its right there under the carpeting
joe
joefong is offline   Reply With Quote
Old 10-11-2001, 06:46 PM   #3
wrx182
Member#: 9531
pink? you mean red? the only wires running from the ebrake are red, white, black...
Old 10-11-2001, 07:31 PM   #4
joefong
Member#: 6611
02 WRX
Its the blue one
theres only one wire coming from the ebrake and its pink. if u are sitting on the drivers seat, its on the right side of the ebrake in the back. u cant miss it. it is pink
joe
Old 10-11-2001, 07:56 PM   #5
wrx182
Member#: 9531
wasn't lookign back far enough.
you were right. thank you very much
Old 10-11-2001, 08:14 PM   #6
toekneepark
Member#: 10042
2004 Turbo IS300
Grey Pearl
uh? can i ask why you guys are cutting that ebrake wire? i only cut the green one, on the left of my steering column and alarm works fine..
toekneepark is offline   Reply With Quote
Old 10-11-2001, 09:40 PM   #7
syntrix
Member#: 9211
2002 wrx wrb
swankmonkey.com
so the ebrake will have to be up to let the TT count down. If someone jumps in your car and lets the brake off, it will shut off immediately!
syntrix is offline   Reply With Quote
Old 10-12-2001, 12:16 AM   #8
Jung918
Member#: 10969
I just installed the type 1 TT and i couldn't really figure out how to take the center console out. I am also still a little confused about the alarm? Where are these wires? are they to the ecu? any info would greatly be appreaceted
Jung918 is offline   Reply With Quote
Old 10-12-2001, 12:26 AM   #9
toekneepark
Member#: 10042
2004 Turbo IS300
Grey Pearl
ok i'll do my best to explain...
i don't know too much about the wire for your ebrake because i didn't cut that wire.. i didn't think it was that important.. but.. the other wire you want to cut.. if you rip open the whole front steering column. you'll see that metal shield under the steering wheel. take that off also.. if you look to the left.. high above, to the left of the steering wheel.. right behind the left air vent.. you'll see the alarm ecu hooked up right behind the vent.. clip that off.. and all wires will be bunched up tied in tape.. cut the tape.. find that green wire.. tape it back up.. put everything back, and there you go..
hope that helped
Old 10-12-2001, 01:18 AM   #10
GDA
Member#: 4324
02 GDA
Platinum
the "pink" ebrake wire is located on the passenger side of the E-Brake handle. it s just a simple female connector.
as far removing the console:
pop open your armest storage bin, 2 screws at the bottom.
then pull the lower cup holder area upward and you will start to see and feel 4 metal clips un clipping them selvers, then that exposes so more screws, ant then untwist the shift knob and pull up the shift boot area and that will pop right off.
then unscrew the remainging screws that hold the bottom of the console to the floor.
good luck
EJ20WRX
GDA is offline   Reply With Quote
Old 10-12-2001, 08:14 AM   #11
wrx182
Member#: 9531
Thumbs up
WEEE....I finished my TT install last night and EVERYTHING works great....I'm so happy!.
Thanks to all that helped me out
if anyone has any questions on doing any of this, feel free to PM me
Old 10-12-2001, 12:08 PM   #12
Jung918
Member#: 10969
Thanks alot...!!! i will go try this out now...
Old 10-12-2001, 01:03 PM   #13
wrx182
Member#: 9531
jung...check you pm
is something wrong with my turbo timer? Hayan STI Mid West Subaru Owners Club Forum -- MWSOC 7 01-12-2005 06:11 PM
How do i wire my windows so that they'll operate with the key off or out? Trizzle Electrical & Lighting 9 05-09-2004 01:26 AM
is there any turbo that will work with the hks d/p? 2002whitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-04-2003 05:35 PM
Anyone Have the Link to That Rally Vid with the Kickin Soundtrack? Ginseng New England Impreza Club Forum -- NESIC 7 06-06-2002 01:02 PM
Where is that silver RS with the PowerPuff Sticker? TeamSUBARU North West Impreza Club Forum -- NWIC 3 04-29-2002 09:33 PM
