Old 05-27-2006, 01:39 AM   #1
EjMiami
Member#: 80844
2004 Wrx Impreza
Wrb
Default My Stock Lug Nuts Suck On My New Wheels???
It was a pain to put my new wheels on the holes to put the lugs on were deep and the lugs are big so the ratchet would scrape the wheels some times. What length lugnuts should I get or can you guys recommend one? The wheels are Work Vs-Xx with 52mm offset.
EjMiami is offline   Reply With Quote
Old 05-27-2006, 01:44 AM   #2
qingshan
Member#: 81322
12/6 Sti/Fo
swp/CGM
Get some skinny ones with a thin key - tuner ones or Gorillas like these http://www.jcwhitney.com/autoparts/P...003863/c-10101
OK - so you think JC Whit sucks
qingshan is offline   Reply With Quote
Old 05-27-2006, 01:46 AM   #3
EjMiami
Member#: 80844
2004 Wrx Impreza
Wrb
Do those come with locks? im looking for a set the also has em'
Old 05-27-2006, 01:50 AM   #4
FWD WRX
Member#: 85592
05 OBP
same thing happened with my rims.. ended up gettin Ray's Dura-Nuts.. it's the extended version
FWD WRX is offline   Reply With Quote
Old 05-27-2006, 04:14 PM   #5
wundej
Member#: 80833
2005 WRX STI
Crystal Gray Metallic
Would deep sockets help? I'm not sure if I'm understanding correctly but you could probably get deep sockets and be in good shape.
Another thing to keep in mind, some OEM nuts will not seat properly on aftermarket wheels. Make sure the nut taper is the same as the mounting surface on the wheel, some lug nuts are more rounded where others are a straight chamfer.
wundej is offline   Reply With Quote
Old 05-28-2006, 01:11 AM   #6
qingshan
Member#: 81322
12/6 Sti/Fo
swp/CGM
They do require that one have the special piece to remove them - 5 locks per wheel?
Old 05-28-2006, 07:44 AM   #7
altezza2impreza
Member#: 95516
2011 WRX
Default rays??
haha i got to thinking.... rays are expensive and some civic (4 lug cheap bastards) could easily take the remaining 4 off your rims and leave the keyed ones "holding" your car up..... go for 2 locks if the rims are worth it.
altezza2impreza is offline   Reply With Quote
Old 05-28-2006, 12:38 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....the Gorilla spline drives will work just great...something like this....
http://cgi.ebay.com/ebaymotors/ws/eB...category=33749
Old 05-28-2006, 03:19 PM   #9
fliz
Member#: 30342
Look for "tuner" style lug nuts. They have a narrower shank, so you can use a smaller socket and not screw up your wheels.
I've got McGards spline drive on my Works. Perfect fit.
fliz is offline   Reply With Quote
nnj wtt my tuner lug nuts for stock sti lug nuts fosingwo Wheels/Tires 0 04-02-2010 01:57 AM
How do I replace a broken lug nut stud on my wrx? Desi_drifter395 Tire & Wheel 6 01-31-2010 08:39 AM
Gorilla spline drive lug nuts & stock lug nuts Boosted Up Wheels/Tires 5 07-10-2008 11:45 PM
Gorilla spline drive lug nuts & stock lug nuts Boosted Up TXIC Private Classifieds 5 07-06-2008 11:33 PM
My (lock) lug nut off my wheel fell off...help lovecars23 Tire & Wheel 18 04-21-2006 05:39 AM
