Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-28-2006, 01:10 PM   #1
nabiljamali
Member#: 102388
Default assembly specs for an ej257
does anyone know where i can find this?
specifically i am looking for piston and cam orientation when installing my heads
nabiljamali is offline   Reply With Quote
Old 05-28-2006, 03:17 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
This is for the WRX 2.0 heads but I would think the process is similar for the 2.5 heads.
The key is to rotate the cams the right way when putting the timing belt on in order to avoid valve to valve interference.
LiquidForce is offline   Reply With Quote
Old 05-29-2006, 01:19 AM   #3
nabiljamali
Member#: 102388
can anyone confirm this?
Old 05-29-2006, 01:21 AM   #4
gpatmac
Member#: 18446
2002 WRX wagon
psm
Confirm the factory service manual?
I followed the fsm and my car runs as it's supposed to.
...and to reiterate:
gpatmac is offline   Reply With Quote
Old 05-29-2006, 01:45 AM   #5
flycaster
Member#: 60142
2011 WRX
Grey
What I think he is concerned about is the manual you're both referring to is for a different engine. To wit: "This is for the WRX 2.0 heads but I would think the process is similar for the 2.5 heads."
If you can confirm that it is exactly the same as the diagram and directions for his motor (which uses AVCS camshafts), then his problem is solved.
flycaster is offline   Reply With Quote
Old 05-29-2006, 02:27 AM   #6
gpatmac
Member#: 18446
2002 WRX wagon
psm
Looks purty much the same to me.
Old 06-03-2006, 05:33 PM   #7
nabiljamali
Member#: 102388
do i set the motor at #1 tdc when bolting the heads on as well?
Old 06-11-2006, 02:22 PM   #8
blacktalon606
Member#: 73316
NO! There is a timing mark to set your timing belt by... and then there is an arrow for TDC. You don't want to set it to TDC when putting the heads on. If you do, and you spin your cams the valves will hit the pistons. Set the mark on the timing belt sprocket (on the crank) that looks like - to the timing mark right above it. Set the single - mark on your top cam sprocket to the timing marks strait up.(which is a pain in the ass... one side the cam has no tension on it but the other side is close to the lobe peak and it wont' stay on the timing mark by itself) Set the single - mark on your bottom cam sprocket to the timing mark 90% off the top cam sprocket. (left side of the motor... its 90 to the left... right side its 90 to the right) Now if you have everything put together right, the double tick marks = on the bottom of your top cam sprocket and the top of your bottom cam sprocket will line up to point perfectly in line with eachother.
blacktalon606 is offline   Reply With Quote
Specs for an alingment Not-EWRX Brakes, Steering & Suspension 2 08-14-2008 02:02 AM
Replacement EJ205 for an EJ257 Sti Shortblock Scoob-GT/WRX Pre-2002 Factory Turbo Powertrain 3 09-16-2007 04:10 PM
Alignment Spec for an '07 STI GBX Brakes, Steering & Suspension 2 05-30-2007 01:49 PM
WTB: Heads for an EJ257 pdare Private 'Wanted' Classifieds 1 04-25-2005 10:01 AM
where do i find the specs for an upgraded stock turbo? tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-06-2003 01:28 AM
