Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-28-2006, 01:26 PM   #1
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
Default Tuna Problems, please help. Very erratic behaviors
I just installed a non-pro tuner system with the VW sensor and i'm having some issues with it. First off the system won't Free Air Calibrate. It goes through all of the motions, but always gives me an ERR1 meaning that it isn't warming up. I have 3 different sensors and all 3 are doing this.
Second is that every other time i start the car the system does its countdown, flashes GAS, then says ERR without displaying any AFR. It'll do this every time i start it when its cold, but once i turn it off and turn the car back on again it operates normally after countdown. Then the next time i start it it'll flash the ERR the whole time until i turn off the ignition then back on again.
What could it be? all tabs are up BTW, none are down and i'm connected to a UTEC.
Thanks
wrxpeed is offline   Reply With Quote
Old 05-30-2006, 10:18 PM   #2
ZR2_S10
Member#: 83865
2005 Saab 9-2X Aero
Midnight Blue
Where did you grab power from?
I got power at the cig lighter, and have not had 1 issue.
I read that if your tuner powers up at the exact time the utec does, it will cause issues.
ZR2_S10 is offline   Reply With Quote
Old 05-30-2006, 11:01 PM   #3
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
i tapped the clock ignition-controlled wire and ground.
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
Please Help!!! Very fast clicking when turning over! ceecel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-17-2009 05:50 PM
Rear Diff. Problem.. Need help very badly!!! Boostises Transmission (AT/MT) & Driveline 5 04-26-2007 11:24 AM
('93-'01) big problem....please HELP!!!!! 25psi Impreza Forum 11 05-10-2001 12:50 AM
('93-'01) Gauge light problems please help me Texas25RS Impreza Forum 1 04-25-2001 08:44 AM
