Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 05-29-2006, 11:15 AM   #1
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
Default who can help? H6 heads - cams reground and porting
I need some direction.
Are there any vendors out there that feel they are competent enough to work with the H6 heads?
I just picked up a motor and I want to build it.
I already have the shortblock covered but I need help with the heads.
This is a non AVCS motor
Should I replace valves?
Should I have the cams reground? ( i am assuming there are no cams available)
Porting?
Is it way to much of a hassle to deal with these things seeing as how it seems this is relatively new to most and there isn't a lot of support in this area?
Any info would be much appreciated.
700hp is offline   Reply With Quote
Old 05-29-2006, 11:58 AM   #2
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Go to: http://www.pdxtuning.com get their phone number and call and talk to Jeff. He can give you ALL the information you need on upgrading the H6 motor for boost.
-Matt
ShaggyGT is offline   Reply With Quote
Old 05-29-2006, 12:15 PM   #3
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yep, give us a call we can help you out
thanks Matt.
Ben
Old 05-29-2006, 12:47 PM   #4
ShaggyGT
Member#: 19221
No problem. You and Jeff are the only ones currently who I would trust taking info from on upgrading the H6 motor.
So are you up at PDX now?
-Matt
Old 05-29-2006, 01:02 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
Yep, made the trek and am back in portland.
Ben
Old 05-29-2006, 01:29 PM   #6
ShaggyGT
Member#: 19221
Sweet!! Trying to get Jarrad to fix me up with some intercooler piping with a Tial flange. I am assuming your doing the welding now?
-Matt
Old 05-29-2006, 01:35 PM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
Dustin, Jarrad and I can all weld so that shouldn't be a problem. Hit me up with a PM or on AIM and we can discuss it so we don't pull this too far off topic
thanks
Ben
Old 05-29-2006, 02:05 PM   #8
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
I'll definatly give them a call and see what they have to offer.
I guess what I am wondering is if is cost effective to do all the head work to the motor at this point.
It always seems that when you are one of the first to modify something that it always costs an arm and a leg. Then a year later, enough people have done it that vendors start offering parts and labor for cheaper. Or you find out that all the work you have done is only gaining you slightly more power than if you would have just kept it stock. (case in point - my last build made 678whp but cost me over 20k and a lot of headwork to get and then I find out that you can get 600whp with just cams ie. Phils car from Element tuning )
What is the case with this motor?
Or is it too early to tell?
Old 05-29-2006, 02:22 PM   #9
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Lets hear some more about this, I don't want to bother PDX tuning with questions that are already being asked, so please do update when you hear back from them,
Sko is offline   Reply With Quote
Old 05-29-2006, 02:31 PM   #10
Shabib67
Member#: 61749
Yea very interested in this thread. I am also putting together the cost of building an H6 Motor. 700hp i was wondering if you could send me a pm with any info regarding the price and requirements to build the H6 motor.
Shabib67 is offline   Reply With Quote
Old 06-02-2006, 10:58 PM   #11
subie4me
Member#: 89218
I hope you have better luck than me. I can't get a return call or email, but hey it's only been a week.
subie4me is offline   Reply With Quote
Old 06-04-2006, 05:53 PM   #12
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
I talked to Jeff Perrin on friday about the h6 motor. From what I could gather He knows what he is talking about when it comes to this engine. Obviously the bottom end of this motor needs to be built but does the top? This is what I was trying to find out from him. He seems to think that the heads of this motor are already set- up pretty well from the factory. Since it comes non turbo from the factory the intake manifold, ports and valves are decent size to flow as much air as possible without aid of being forced in by a turbo. Also the factory cams have quite a bit of lift. He did say however that the factory springs should be replaced as they are not that stiff. Obviously any porting work can only help with power.
Here is what I found in looking at the set of H6 heads I have in my garage-
Keep in mind these are non AVCS so specs may be different from AVCS heads
The intake and exhaust valves are almost identical to sti valves in size (maybe a few thou different, i didnt measure)
The springs also appear to be identical to sti springs in diameter in height and in strength.
I think that I may just keep everything on the top end stock (except for some porting) and see how she does. I can't justify spending a whole bunch of money on a set-up that appears to be very good from the factory.
NEED HELP!!! ID Heads/Cams! 02WRXNY Built Motor Discussion 2 08-21-2008 06:51 AM
NEED HELP!!! ID Heads/Cams! 02WRXNY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2008 08:59 PM
HELP! My head cam seal fell into the motor f1uxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-11-2006 12:34 PM
need help with a assignment , who can help me... method2madness General Community 42 08-04-2004 08:17 PM
Attn: Late Model Legacys and those who can help... SubieKidTK Legacy Forum 11 05-11-2001 06:02 PM
