Old 05-30-2006, 11:24 AM   #1
engr
Member#: 62911
Default tuning out -kc at low rpm?
I drive an 4eat and my logs are showing upto -7 KC when I accelerate hard in the range of 1k - 2k RPM just at the beginning of accelerating. What can I do to tune it out? I've got access to tuning software, but don't know what to do or how to do it.. I was going to try to increase fuel to that area and decrease timing by 3 degrees or so to see if I can get the -kc to dissapear. It runs great the rest of the power band with kc's hitting upto 12.. it's just the damn automatic is so sluggish at the low end and bogs like crazy.
anyhelp would be appreaciate.
engr is offline   Reply With Quote
Old 05-30-2006, 11:29 AM   #2
Freon
Member#: 88322
2009 BMW 135i
You likely cannot change fueling there since you will almost always be in closed loop in that range. You can lower timing in the base timing maps. There are probably two base timing maps. Leave the ignition advance maps alone.
Do you have logs? Can you post them?
Freon is offline   Reply With Quote
Old 05-30-2006, 12:02 PM   #3
engr
Member#: 62911
I couldn't find any file hosting.. but here's a printscreen of the log
so the only thing that I can control is timing in closeloop?
Old 05-30-2006, 02:01 PM   #4
Freon
Member#: 88322
2009 BMW 135i
Looking at that, you can tweak down a bit of timing near the 1.5-2.0 load columns from 1200-2000rpm. That's my suggestion...
Old 06-11-2006, 08:52 PM   #5
MRF582
Member#: 48219
. Always drive
the race line .
It looks like there is a rattle that occurs at low rpms. Heatshields? It's causing the knock sensor to pick up 'knock'.
MRF582 is offline   Reply With Quote
Old 06-12-2006, 07:45 AM   #6
Spiider
Member#: 13680
I had this problem early on too, I see you have a knock event at the area of the -ve KC, look around for something loose on the engine, or rubbing in your engine compartment.
Mine was the STi intercooler rubbing on the metal a/c line near the firewall.
Could be a loose heatshield as mentioned.
Spiider is offline   Reply With Quote
Old 06-12-2006, 01:29 PM   #7
Freon
Member#: 88322
2009 BMW 135i
FWIW, I see the same thing on my car. 0 to -2 KC at cruise. But it still runs like +40 degrees cruising. I've slightly dialed back some areas on my timing map where I was seeing the -2. I haven't logged enough yet to say if it has made a difference.
I don't think you'll ever get positive KC in those areas because the advance maps don't really kick in until higher load.
Old 06-12-2006, 07:19 PM   #8
Jon [in CT]
Member#: 2992
02 WRX Sedan
These negative Knock Correction values are almost certainly the result of throttle tip-in. You can confirm this by logging while cruising at, say, 3500 RPM and then flooring it and making sure the AT doesn't down-shift. Did you record some negative Knock Correction before the throttle opening reached 100%? I'll bet you did.
There are usually separate tables for throttle tip-in fuel enrichment and spark retard. Don't mess with the general fuel enrichment and spark advance tables to "cure" this.
Jon [in CT] is offline   Reply With Quote
Old 06-13-2006, 11:32 PM   #9
jpmarotta
Member#: 20391
'01 Range Rover HSE
NESIC TrackHoh #555
Thumbs up
Originally Posted by Jon [in CT]
These negative Knock Correction values are almost certainly the result of throttle tip-in....
I concur with Jon. If you can, bump the tip-in values down at least 1 point across the board, should help with overfueling/bogging/throttle knock.
-Jason
jpmarotta is offline   Reply With Quote
Old 06-14-2006, 02:49 AM   #10
engr
Member#: 62911
when you say bump down 1 point, you mean removing 1 degree from the entire table?
I don't think it's any loose parts.. it gets worse when I run 91 octane fuel... and I don't hear any rattle or thumps while accelerating..
Old 07-02-2006, 10:34 PM   #11
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Follow-up?
Beanboy is offline   Reply With Quote
Old 07-07-2006, 11:54 PM   #12
engr
Member#: 62911
I'm working on a completly different tune using ecu edit with someone.. and there are no more -kc's. but there are other problems
Old 07-08-2006, 02:18 AM   #13
3barboost
Member#: 73609
2002 wrx
- KC is not a bad thing thing
The Ecu is smart to know that if it applies its full timing correction - det will occur
ifyou at low revs and go wot - the ecu will pull back timing - funnily enough ust like an old vacuum operated dissie
its part of its ability to detect / prevent and in some cases predict knock
I would leave those values alone and not try tune them out - as you will then leave yourself compromised in other areas of the map
make up a set of DET cans and listen to the engine you will learn that its not actually knocking - the ecu sees a certain load as derived from the MAF - a certain rpm a certain road speed and it knows that it needs to pull timing in order to accelarate and also prevent det - det doesnt actually occur - the ecu is being smart
3barboost is offline   Reply With Quote
Old 10-24-2006, 12:57 AM   #14
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
ill bump this as i too have teh auto with the same problem, but my tip in is almost freaky how bad it is, and its not all the time.
OvrClkdPmp is offline   Reply With Quote
Old 11-08-2006, 12:01 AM   #15
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
you could bump up the knock detection range above where your problem is if you simply want it to go away
otherwise, its knocking! thats why it shows knock!
Turbo_Mike is offline   Reply With Quote
Old 11-08-2006, 12:18 AM   #16
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
yea thats great but how do you fix it without "tricks"
Old 11-08-2006, 02:07 AM   #17
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
You lower your base timing...
drees is offline   Reply With Quote
Old 11-08-2006, 11:53 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
there might also be other compensation maps in play.
Old 11-08-2006, 07:01 PM   #19
Freon
Member#: 88322
2009 BMW 135i
FWIW, I have always seen an occasional -2 KC around 2400-3200rpm at cruising load levels (0.4-0.8), even when not changing throttle position. It comes in and out and isn't consistent. I tried removing 2-3 degrees in that area from base timing. It does seem to limit this from happening, but doesn't completely stop it. I'm not sure I would worry about a -2 KC in this range while cruising or under light throttle.
I don't have a good explanation for it, but it is something I'll try to look into at some point.
Old 11-13-2006, 01:29 PM   #20
rt4me
Member#: 82786
2004 WRX
I'm really new to tuning and am seeing the same thing. So -1 or -2 KC isn't something to worry about? I also noticed that my IAM stayed at 16 the whole time (I have is set to start at 12). Under what circumstances is the IAM reduced if it isn't when knock is detected? My timing showed to be pulled (usually from around 40 to 37-38) but the IAM doesn't budge.
rt4me is offline   Reply With Quote
Old 11-13-2006, 01:47 PM   #21
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I am not sure what causes the IAM to drop, I think more than a little bit of knock will make it drop. So far, the 2 automatic WRXs I've tuned/logged have low rpm, tip in -kc. The Manual did not have any -kc anywhere no matter what we did with the throttle.
I think next time though, I'll take a log of knock sensor voltage and see if there are spikes at all. Or if the ECU is just pulling timing because of something the TCU is telling it.
Old 11-13-2006, 05:41 PM   #22
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
that would be great if you could do this
Old 11-13-2006, 06:14 PM   #23
Master2192
Member#: 83254
98 2.5 RS
04 WRX
^^^ Was that directed at me?
Old 11-13-2006, 06:24 PM   #24
CynicX
Member#: 48199
06 WRX
If it wasnt I would direct the same question toward you....It would be great if you could read the volts to see if its actually detecting or if its the ECU....
I dont have an auto, nor do I know anyone that does but I still just as curious to learn what exactly is happening for future reference....
CynicX is offline   Reply With Quote
Old 11-13-2006, 06:29 PM   #25
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Alright, I'll try to get a log of the knock sensor tonight. Will be doing a 40 mile drive at cruising so I can get in some low rpm tip-in as well as some shifts to see what is happening.
08 2.5i AT pinging at low RPM when warm out... normal? SportshiftedSSM508 Normally Aspirated Powertrain 79 07-28-2013 01:45 PM
Power assist cuts out at low RPMs ('05 STi) case Brakes, Steering & Suspension 2 02-22-2008 10:49 AM
How to tune out -kc at low RPM? engr UTEC 4 05-30-2006 11:08 AM
('93-'01) Little ratling at low rpm. Opinions? tonytiger Impreza Forum 8 06-14-2001 09:29 AM
Car "stutters" at low rpm smallschip Newbies & FAQs 10 03-09-2001 12:22 AM
