Old 05-30-2006, 03:08 PM   #1
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
Default Can a dealer tell ?
If a person used a Cobb Accessport on an 06 STi and then set everything back stock to go to the dealer, would he be able to tell ? I haven't bought one yet, mainly because of questions I have like this ! I'm sure someone here can fill me in. Thanks, Okey
Okeyd57 is offline   Reply With Quote
Old 05-30-2006, 04:02 PM   #2
Annapolis Subaru
Member#: 107051
One you un-marry the AccessPort from your ECU a dealer should not be able to tell that you had it installed. I am sure that there are some exceptions to this but in a general sense it should not be detected.
Thanks,
Jackie
Annapolis Subaru
443-837-1422
Annapolis Subaru is offline   Reply With Quote
Old 06-01-2006, 07:23 PM   #3
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
I can tell with a $80 cable. So I am sure some dealers can. If you want to be sure, get the Tactrix cable, and back up your ECU first. That way you can go back to your actual ECU, not the COBB generic ECU they use.
bofh is offline   Reply With Quote
Old 06-01-2006, 08:02 PM   #4
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Un-married or not, the new Subaru Select Monitor 3 will immeadiately recognize if an ECU has been reflashed. The previous versions of the Select Monitor will not. It does this by comparing the ECU programs checksum values and comparing them with the ECU's calibration ID. Once an ECU is flashed, these do not "match" any longer.
Opie is offline   Reply With Quote
Old 06-01-2006, 08:09 PM   #5
pornstar1969
Member#: 98569
07 STI SWP on sale
GT35r 396whp on 93
does this happen if you use utec too.
pornstar1969 is offline   Reply With Quote
Old 06-01-2006, 08:21 PM   #6
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Utec (from what I understand) is a piggyback to the ECU and does not actually change the programming in the ECU. So as long as the UTEC is not present when they check the car, it is doubtful it would be detected.
Old 06-01-2006, 08:26 PM   #7
pornstar1969
Member#: 98569
07 STI SWP on sale
GT35r 396whp on 93
I have it, that is what i though would happen but wasn't sure how it and the computer communicated. If the comp. stored any info.
Old 06-01-2006, 08:27 PM   #8
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
I believe that dealer can detect any ECU reflash starting with the 05 and later models.
ScoobyNubieToo! is offline   Reply With Quote
Old 06-02-2006, 11:30 AM   #9
Corkfish
Member#: 39503
Does that make the 04's more valuable?
Corkfish is offline   Reply With Quote
Old 06-02-2006, 11:52 AM   #10
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Bingo!!
I have been saying that same thing for well over a year now (we were the pilot dealer for the SSM3)
Old 06-02-2006, 12:41 PM   #11
Freon
Member#: 88322
2009 BMW 135i
Ok, this begs the question.. What happens if the dealer flashes for a TSB? Does it fix the calibration ID to match the new checksum value? Is there byte in the ROM that has to be modified to make the resultant checksum match the calibration ID?
If so, I wonder what it takes to fix the calibration ID. If the dealer can do it, an individual could with the write tools. We already had to defeat one checksum routine on Openecu.org for the DBW Subarus.
FWIW, you can always flash back a TRULY stock image if you pull your original ECU image out with Ecuflash (openecu flash). You get a bit for bit backup and the checksum won't change if you flash back using that image. I understand the AP does not actually backup your ECU during a marry, it only flashes back a genericised image that is made for your ECU when you unmarry.
There is a built-in checksum on DBW Subarus that has already been defeated anyway. I don't think this should be a particular challenge for anyone that concerned about it.
Freon is offline   Reply With Quote
Old 06-02-2006, 01:28 PM   #12
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
If a SOA reflash is performed the ECU will have a new checksum and Calibration ID, that combination is a known value that the SSM3 recognizes as a valid combination.
Once the ECU is reflashed it cannot be flashed back to a stock map on be "OK" as the stock/original calibration ID will not match the checksum as the checksum changes its value each and every time a flash is performed and can not be manipulated to be a certain checksum.
For example, say you are running a stock flash with calibration ID: "A" and checksum of "1" and you reflash and the new calibration ID is "X" and the checksum is then "2". You decide to reflash back to stock and now the calibration ID is "A" again but the checksum is "3"....not a valid combo.
Old 06-02-2006, 01:36 PM   #13
shemoves
Member#: 80663
2005 STi
For getting warranty work done there are two methods that work. 1) Don't mod it 2) be honest from the get go. History on the boards has shown that people that were up front about what they did to/with the car, and were cool about it when presenting problems to dealers, still got there warranty work done. Caveat to #2...don't beat the car to the ground (i.e. drop the clutch, not to regularly scheduled maintenance) and expect it to be covered.
These cars are built well and Subaru knows that.
shemoves is offline   Reply With Quote
Old 06-02-2006, 01:39 PM   #14
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Thanks for the clarification Opie.
However, I'm sure there's a way around it... It's very possible that even Subaru won't know how to do it. But the actual people/company who make the chip do.
It's a matter of how dedicated these "hackers" are. Anyone know who makes the Subaru ECU memory?
FD777 is offline   Reply With Quote
Old 06-02-2006, 02:16 PM   #15
leecea
Member#: 37359
2003 WRX
I thought there was a hard limit to the number of reflashes. If that's true, there must be a counter somewhere too.
leecea is offline   Reply With Quote
Old 06-02-2006, 02:38 PM   #16
Okeyd57
Member#: 113271
2006 STi
I knew this was going to be a good question !
Old 06-03-2006, 12:00 PM   #17
badtaste
Member#: 116636
2003 impreza
black
yes with our new subaru laptops at work. as soon as we plug in we can tell anything that has been moded electronicaly and it automatticaly will send to SOA and kill your warrenty. Be carful if your worried about a warrenty.
badtaste is offline   Reply With Quote
Old 06-03-2006, 12:02 PM   #18
Hondaslayer
Member#: 4562
1995 Legacy LSi
Don't spread misinformation.
Old 06-03-2006, 01:20 PM   #19
CynicX
Member#: 48199
06 WRX
The limit is due to the ECU not being able to tolerate being changed anymore. The memory wasnt designed to be flashed hundreds of times.
I thought the number was 500-600 flashes before its burned out. If thats true then no one really has to worry about it.
OP: With what Opie says the dealer will be able to know. But if all you have done is a reflashed ECU I doubt they will bother. Now if you have exhaust and turbo and try to convert back to stock to get warranty work done then they can easily tell just by looking at the work. They will also probably not provide you with warranty service in that situation.
Be honest too. Warranty work doesnt pay as much as regular work. The tech dont get the same about of time. Example : Replacing a strut may pay the tech 3 hours of time (guessing) warranty strut replacment will pay 1.5 hours. This is why they dont like warranty work. It helps Subaru because the dealers and tech dont want too if they can help it but it hurts the techs if they have to do it.
CynicX is offline   Reply With Quote
Old 06-17-2006, 10:39 PM   #20
80884
Member#: 56783
2004 sti
Aspen white
Thats a good one, So if I mod my computer and bring it to you, you will void my warrenty? Riiiiight, thats not the way the system works. If you work at subaru than you should know this. One example of this is when I first had a transmission problem. I called subaru and asked them if the dealer can deny warrenty work if I have a TBE. They said in no way can they say that the exhaust caused the problem with the transmission untill they personally take the car apart. She then said.."you could put an entirely different engine in the car and it will not void your warrenty, If you had transmission problems even with the different engine they would still have to prove that the engine cause the transmission problem."
Another example - Mod ecu, injector goes bad. I'm guessing the only possible way that the injector could have gone bad is from the modded ecu right? I'm not sure where you work but if you don't mind could you tell us?
Riiight, Like I said above strait from the horses mouth..."they have to prove that the mods caused the problem otherwise it's still under warrenty" If the dealer sees mods and says they won't cover problems report them to subaru and they will be looked into. If they claim that the mods cause the problem ask them for a write up on how they confirmed that the mods caused the problem.
If you modify and/or abuse your car, that is not reason for your warranty to be voided. IT HAS TO BE PROVEN that the modification and/or abuse caused the defect. And even then your warranty is not voided, the warranty claim was just denied. Other things on your vehicle not affected by the modification and/or abuse are still covered.
If you are ever told that your warranty is "voided", make sure they are saying the ENTIRE warranty is voided, and not that the warranty claim was denied. If they say that the warranty is voided, get it in writing and call SOA. Most likely it is just the claim that was denied.
Either way, if you mod something say exhaust and ecu and your turbo starts to have problems. You messed it up, don't try to get it covered under warrenty. I guess you could tho cuz some dealers don't care about mods and you would get a new turbo anyway. While some dealers look for mods to get an easy way out of fixing the car for less money than charging the regular non warrenty rate. I belive 75% of the warrenty problems are with the dealer, not subaru.
80884 is offline   Reply With Quote
Old 06-17-2006, 10:54 PM   #21
Hondaslayer
Member#: 4562
1995 Legacy LSi
Actually for customer pay we charge 1hr per strut, warranty pays 1.2 hrs
Old 06-18-2006, 12:15 AM   #22
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
If you worry about what you are going to do with your car in order to keep the warranty in tact, then don't do it.
RexyGirl is online now   Reply With Quote
Old 06-18-2006, 08:47 AM   #23
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
ECU's are not that expensive on the used market.
Old 06-18-2006, 10:37 AM   #24
Hondaslayer
Member#: 4562
1995 Legacy LSi
The OP has an 06 STI.
If he buys a used ECM he is going to have to take it into the dealer to have it programmed into his BIU. That might raise a red flag or 15........
Old 06-18-2006, 10:54 AM   #25
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Is this somewhat symilar to what VW does when you "commision" a module? You install it, connect to the port and select the options of the car, in order to have the unit working?
If so, I understand, untill the commisioning software becomes more or less available, it's a problem. The WAG (VW) software ended up becoming available , in time.
A friend had to replace the ABS module, so had to hook up the Lap-top containing the software and complete the installation procedure. My understanding is that this allows the factory to save money by installing "universal" control units, which are then programmed specifically for the car.
can the dealer tell if you have a tuner els.sti Newbies & FAQs 33 05-02-2008 02:42 PM
Can a Subaru dealer tell if an ECU has been EcuTek flashed? benw Commercial ECU Reflashes 6 01-15-2007 04:16 PM
Can a dealer tell Okeyd57 Warranty Issues & SOA Problems 4 06-01-2006 05:02 PM
Could dealer tell if i got new ECU??? 05STI!!! General Community 12 04-20-2005 09:12 PM
Can the dealer tell that I've buzzed the engine? toerag Service & Maintenance 7 10-17-2001 06:18 PM
