Old 05-31-2006, 01:59 AM   #1
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Default Anyone else find a H6 PCV on their 2005 WRX?
Thats right you heird it, I went to change my PCV on MY05 WRX and what did I find! The PCV that always was for the H6 was on my wrx. Its still in the same spot as the 2004+ wrx or when ever they changed it. On the oposite end of hose on the intake manifold below the throttlebody.
Did SOA change this in 2005?
My cars date of birth is 05/04(may 2004).
Has anyone with a 2005 2.0L wrx changed the pcv?
Did SOA run out of wrx pcvs' the day they were putting my Ej205 together?
Could there be any benefit in using one or the other? The wrx pcv has a larger hole for venting.
Could the smaller hole in the H6 pcv make the engine drop in rpms faster between shifts, because not as much air is being vented back into the intake
I replaced it with the H6 pcv and the car feels smoother at idle and drops rpms faster between shifts.
The car has 50k (DRIVE MUCH?) and the pcv has a bit dirty, not really dirty but im O.C.D. and seem to notice everything and its cheep.
Any input would be great.
Thanks,
rexworx is offline   Reply With Quote
Old 05-31-2006, 11:11 AM   #2
rexworx
Member#: 103232
bump!
Old 05-31-2006, 06:34 PM   #3
rexworx
Member#: 103232
bump cause im a chump!
Old 06-01-2006, 10:46 AM   #4
rexworx
Member#: 103232
im still a chump thats done alot of searching
Any info anyone?
Old 06-01-2006, 04:14 PM   #5
JRSCCivic98
Member#: 67080
The PCV changed designs in 04+ cars. It's the small outlet one, should be silver. It's also placed in a 90 degree elbow right below the passenger side I/C bracket (or right around that area).
JRSCCivic98 is offline   Reply With Quote
Old 06-01-2006, 05:21 PM   #6
rexworx
Member#: 103232
Thanks for the reply, i know where the pcv is, i changed it.
When i changed the pcv it was the one for the H6, not the one for the H4.
Its still on the plastic t fitting on the other end of the hose coming the intake manifold. Where the pcv was before.
Old 06-01-2006, 10:19 PM   #7
JRSCCivic98
Member#: 67080
Then you should know the H6 and H4(04+ models) use the same freaking PCV. That's why you think it's for an H6. The tip on it that the hose clamps on in not wide as it was in 02-03... it's thin.
Old 06-01-2006, 10:25 PM   #8
rexworx
Member#: 103232
I C I thought it was the valve, it was just in a different location.
Thanks for clearing this up for teh noob!
Old 06-01-2006, 10:27 PM   #9
JRSCCivic98
Member#: 67080
Now you have me confused... are you saying the valve was in the exact same location as on the 02-03 models, but the valve was an H6 version? That's not possible.
Read this... pay close attention to Peaty's post in the middle of the thread.
http://www.scoobymods.com/forums/sho...ight=pcv+valve
Old 06-01-2006, 11:32 PM   #10
rexworx
Member#: 103232
the valve is in the right place, its just the H6 pcv i didnt know that was what it was changed to.
Old 06-01-2006, 11:35 PM   #11
rexworx
Member#: 103232
THANKS!
Old 04-20-2012, 07:44 PM   #12
SubieMonte
Member#: 264803
2005 WRX Wagon
Bump from the dead
Can someone please post pics of where the pcv is on the 2005 WRX 2.0? Much function is dysfunctional. Thank you!
SubieMonte is offline   Reply With Quote
Old 04-22-2012, 06:34 PM   #13
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
Im sure its the same on my 2004 wrx. If you look near the throttle/cruise cable you should see a black T piece thats connect to the block. One part of the T goes into the turbo inlet and the other Side of the T connect the the intake manifold under the throttle body.
Cois32 is offline   Reply With Quote
Old 04-22-2012, 07:43 PM   #14
SubieMonte
Member#: 264803
2005 WRX Wagon
Well I'm sure I've been there a couple times but the PCV the import shop sold me appears to be a bit larger at the tube. Any chance you could take a photo?
Old 04-24-2012, 02:53 AM   #15
Subawuu20
Member#: 317744
http://forums.nasioc.com/forums/show....php?t=2240991
found another old thread. seeems like he removed the actual valve from the unit but just buy the whole assembley if your gonna mess with it. it was 37$ from the stearler ship
Subawuu20 is offline   Reply With Quote
does anyone have a greddy 1518z 18g on a 2005 wrx? hatrick32000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-02-2008 10:57 PM
does anyone else find those mortgage ads on cnn annoying Indocti Discant Off-Topic 3 03-28-2007 01:43 PM
Anyone have the SPT decals on their 2005 GT? kinbud Legacy Forum 1 08-26-2004 12:39 PM
Anyone else ever had this idea for their WRX?? waitandbleed92 Off-Topic 1 02-01-2004 01:58 AM
w00t! anyone else find their x-mas presents poorly hidden? RaceCarRiot Off-Topic 2 12-19-2003 02:56 PM
