Old 05-31-2006, 11:51 AM   #26
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
You wouldn't even need a ply wood top. Just 3 or 4 ties roped/chained together will work well.
beethoven is offline   Reply With Quote
Old 05-31-2006, 11:52 AM   #27
Humpty
Member#: 105194
wow you must be
swingin some serious pipe
Originally Posted by BhamRoadrunner
Yea, I dunno about the chain part, but Sourcing some plywood other than the outdoor variety should be easy and those ties are very cheap anyways. No need for stakes since the ground on either side is mud. Basically its a creek running through the middle of a swamp I can just sink the ties in the mud with a 10# sledge. The chain isn't an option as the nearest vegetation for a few hundred yards is wild reeds.
90-100#'s isn't too bad, I can haul those in by myself. Won't exactly be too fun, but I can do it.
Just that way it does not float away and block creek down river, lots of damage that way. If you can even find a good stake to drive in you will be better off. When I lived in Mobile we had to build one for the drainage ditch.
Of course when it rained we would "Surf" 3 ft wide pices of plywood down the drainage ditch...it sucked being poor.
Humpty is offline   Reply With Quote
Old 05-31-2006, 11:53 AM   #28
Humpty
Member#: 105194
wow you must be
Rather hard to get a wheel barrel across then though. This way it is flat and easy to cross.
Old 05-31-2006, 11:53 AM   #29
Blknblu
Member#: 29188
Chapter/Region: PRSIC
2000 Ducati M900
Blknblu is offline   Reply With Quote
Old 05-31-2006, 11:55 AM   #30
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
mind if I ask you kwai?
SkirtBoy is offline   Reply With Quote
Old 05-31-2006, 12:00 PM   #31
aod
Member#: 7121
Make it out of carbon fiber. Because, well, you know.
aod is offline   Reply With Quote
Old 05-31-2006, 12:04 PM   #32
BhamRoadrunner
Member#: 87294
98 Silver
POS
Because there's no other way to my favorite fishing hole.
Hey HG21, don't dis on surfing plywood down the drainage canals. There wasn't alot more to do in the ghetto-ass west bank of New orleans growing up either
I'll see how big the spikes are. I might actually have to use poles and somehow tie them to the bridge... Brackets and 16 penny nails maybe?
BhamRoadrunner is offline   Reply With Quote
Old 05-31-2006, 12:10 PM   #33
fliz
Member#: 30342
FYI...you can make any length spike out of a sharpened piece of rebar.
My dad used sharpened 2 foot lengths as spikes for some of his "natural" construction projects (read:stuff built with tree trunks).
fliz is offline   Reply With Quote
Old 05-31-2006, 12:13 PM   #34
Humpty
Member#: 105194
wow you must be
16 penny will not hold much against water, go with the above posters Rebar idea, will work easy and is cheap.
Ghetto surfing was fun, though miss time a cross bridge and you end up eating all kinds of foul water on the other side. Made hurricanes fun though. LOL
Old 05-31-2006, 12:13 PM   #35
BhamRoadrunner
Member#: 87294
98 Silver
POS
Ummm sharpened with what? I don't have a grinding wheel available for use.
Old 05-31-2006, 12:20 PM   #36
fliz
Member#: 30342
Then go to a machine shop.
Actually, if you have a drill bit, you don't even need to sharpen.
Just pound it in with a 6 lb mallet.
Old 05-31-2006, 12:21 PM   #37
BhamRoadrunner
Member#: 87294
98 Silver
POS
I do have that. Drill all the way through or no?
Old 05-31-2006, 12:23 PM   #38
Humpty
Member#: 105194
wow you must be
If you have a lot of shale maybe, most likely just mud and small rocks. Use that big burly body of your and give the stake of love to Mother Earth.
Old 05-31-2006, 12:25 PM   #39
BhamRoadrunner
Member#: 87294
98 Silver
POS
Lots of Clay actually. Once you get past about 2 feet of mud, it's all clay.
Old 05-31-2006, 12:29 PM   #40
fliz
Member#: 30342
I'm confused.
I'm talking about using a piece of rebar to hold the 4 or 5 railroad ties together.
Just drill a hole slightly smaller than the rebar and pound it in. You'd want to drill all the way through.
If you're talking about staking it into the ground to keep it in place in a flood...you'll probably need something bigger and stronger than rebar.
Old 05-31-2006, 12:29 PM   #41
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
It was a joke.... 'bridge over the river Kwai'.
Funn4y not found
Old 05-31-2006, 12:42 PM   #42
Vacca Rabite
Member#: 55491
WRX, 1968 Jeep m715,
1976 VW Porsche 914
real rail ties weight between 150 - 250 pounds, depending on how old they are and how much cosmoline they are still soaked with.
The fake "rail road ties" the people use for gardens and such weigh far less.
Erin and I bought 16 8 foot ties to put around our garden. They were used ties, retired for rail service. Some of them were closer to the 250# mark, some were not.
Retired ties will cost about $10 - $20 a tie + shipping. Or feww if you drive around the tracks with a truck.
Zach
Vacca Rabite is offline   Reply With Quote
Old 05-31-2006, 01:01 PM   #43
sarahslover
Member#: 115008
I'm just Sarah's
punk bitch!!!!
Actual railroad ties are ~150 pounds or better due to the creosote. When I was in the Marines, myself and a squad of 10 Marines moved over 1500 from a rail line. Stout, weather resistant and a bear to move alone, but sling it up on your shoulder for a nice painful work out. 4 will work just fine, just be careful you don't hurt yourself.
FYI, cosmoline is what is used to pack weapons to prevent rust/corrossion
sarahslover is offline   Reply With Quote
Old 05-31-2006, 01:12 PM   #44
Grap
Dicky Nipperist
Member#: 6590
I downloaded this one program a while back that allowed you to engineer bridges and then you could test them under stress to see how they worked.
There was a thread about it a while back.
Grap is offline   Reply With Quote
Old 05-31-2006, 02:23 PM   #45
BhamRoadrunner
Member#: 87294
98 Silver
POS
150... Well it's been a while since my time in service, that might be a bit closer to a bear of a workout.
Sorry I'm back from lunch now.
Old 05-31-2006, 02:25 PM   #46
Humpty
Member#: 105194
wow you must be
I mentioned earlier that with out creosote they are 90 or so. It seems like ashort term thing for you so not sure you need the treated ones. Borro wan ATV and a chain and make the job of getting them there fun
Old 05-31-2006, 02:27 PM   #47
BhamRoadrunner
Member#: 87294
98 Silver
POS
Eh, I'm fat, I could use the work out.
Maybe carry them across my shoulders and do my Jesus impersonation
Old 05-31-2006, 05:51 PM   #48
ak ryda
Member#: 35920
2014 Jeep SRT
13 Polaris LE Pro RMK 800
Like others have said, real rail ties weigh 200-250 for 8' creosote treated ties. I just loaded, unloaded, drug, and stacked about 30 this weekend by myself and I gurantee you they are over 200 pounds. Behind my office the railroad took out a couple thousand and replaced them with concrete ties so needless to say a few have migrated elsewhere. It is just about the max that a single person would want to work with and no way in hell would I transport them by throwing them on my shoulders and walking, they are not like throwing the squat bar on your back. They are big and aukward and I would not want to get caught between the ground and the tie if I tripped.
Look for four 10' railroad ties, use whatever decking you want, span the creek and leave it. If they fall in just get pull them back out since they wont float away.
ak ryda is offline   Reply With Quote
Old 05-31-2006, 05:53 PM   #49
BhamRoadrunner
Member#: 87294
98 Silver
POS
Hmm.... 250... Sheesh I might have to go try and pick one of these buggers up tonight after work.
Sounds like I might need to work on my squats.
Old 05-31-2006, 06:13 PM   #50
Fuzz541
Member#: 4739
Jeez. Rail ties are total overkill.
Why bust your ass so much when you can easily get the job done for a few more bucks using 6x6's and some plywood? The wood will last a couple of years if you soak it with poly or Thompson's. Use pilot holes and galvanized spikes for assembly. If you want to make the bridge wide, use 4 12' 6x6's and separate them with block cutoffs from the extra long 12's.
Fuzz541 is offline   Reply With Quote
OT ti89 users, a little help.. 97whitesi Off-Topic 20 02-15-2006 11:30 PM
EJ22T motor has no bottom bolt for the starter?? A little help please... Fitz Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-18-2001 12:27 AM
Pleiades? little help please? :) Motohead1 South East Region Forum 1 09-11-2001 08:53 AM
Emblems, little help please zkb General Forum Archive 5 10-19-2000 09:39 PM
I need a little help, please read! Boom New England Impreza Club Forum -- NESIC 3 05-30-2000 01:26 PM
