Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-31-2006, 05:10 PM   #1
limestoner
Member#: 35490
97 Impreza 2.2l
slow.
Default stripped cam sprocket bolt
I stripped the passenger exhaust cam sprocket bolt while trying to remove it.
so far i see a few options to remove it-
-vice grips
-tool for stripped bolts
-heat the bolt and hammer in a larger hex, wait until it cools and then try to pop it.
-weld a hex wrench in the stripped bolt
i tried the vice grips and they wouldn't hold the torque needed to pop the bolt.
would heating/welding on that bolt fuse it to the cam, thereby making a bad situation much worse?
limestoner is offline   Reply With Quote
Old 05-31-2006, 06:21 PM   #2
Cation
Member#: 88779
00 E55 AMG
gator grip....
I don't know if I'd heat up that bolt at all man, never had that area of the motor open, but someone has...
Cation is offline   Reply With Quote
Old 06-01-2006, 03:26 PM   #3
limestoner
Member#: 35490
97 Impreza 2.2l
slow.
anybody? bueller?
Old 06-02-2006, 09:45 AM   #4
gotsol
Member#: 17346
08 Cayman S
I'd leave the heat out of it since you could hurt the cam seals. Welding is a good option but again it would heat the seal (not as much as a torch though)
This is a hex head bolt?
gotsol is offline   Reply With Quote
Old 06-02-2006, 09:55 AM   #5
subieworx
Member#: 47769
So you just killed the head of the bolt? If so get the Craftsman (or equiv) bolt extractors. They look somewhat like a normal socket, but have sharp grooves on the inside that grip the round head of the bolt. They work amazingly well.
subieworx is offline   Reply With Quote
NON AVCS cams and EJ257 heads ADJ cam sprockets saintluciascooby Built Motor Discussion 12 01-23-2012 10:12 PM
Stripped 10mm Hex Cam Gear Bolt!! HELP!! onemoreday21 Built Motor Discussion 41 11-17-2008 03:27 PM
Cams and cam sprocket for STI? hauvis Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-11-2005 11:43 PM
WRX oil pan, Cam sprockets, Cam Cover's etc fimotorsports Private 'Wanted' Classifieds 0 10-30-2003 02:19 PM
Adjustable cam sprockets Kikos Fonseca Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-22-2002 11:54 AM
