Old 01-15-2011, 11:21 PM   #1
Sideways
Member#: 6295
2016 WR Blue WRX #7
I thought the turn signal bulb on my 2011 burning out was a fluke, but doing a search uncovered it was a widespread thing...
http://www.clubwrx.net/forums/genera...rn-signal.html
Granted this is minor, but it is still funny. You'd think Subaru or their supplier would have caught a bad batch of bulbs.
Can't wait to spend my Sunday afternoon pulling my battery and trying to squeeze my hand into a tiny little hole to get this bulb swapped.
Sideways is offline   Reply With Quote
Old 01-17-2011, 12:28 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
It's covered under warranty...take it in and get it repaired properly
RexyGirl is offline   Reply With Quote
Old 01-17-2011, 12:48 PM   #3
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
So you come in here and complain about it, then you complain about how a company doesn't catch some bad bulbs burning out before they install them and then bitch more about removing the battery to replace your bulb when it is covered by warranty for 3/36k?
I hope that model doesn't require part of the bumper coming loose to remove the light.
Ummm what?
blackfang is offline   Reply With Quote
Old 01-17-2011, 10:14 PM   #4
SubeTek
Member#: 1714
1999 RS-T COUPE
There is actually a Tech Tip from Subaru's January issue for just this problem.
Before replacing a head-lamp assembly for a Customer concern of a turn
signal that blinks too fast, check the wiring as it enters the turn signal bulb
socket. There may be too much tension on the wires that could be causing a
poor connection. Slightly re-routing the wire harness to alleviate the tension should take care of the problem.
have your dealer look this up for more info.
SubeTek is offline   Reply With Quote
Old 01-20-2011, 05:43 AM   #5
speedy_beedee
Member#: 181469
2009 Impreza GT
um my 09 Impreza gt has had this problem. I don't think this is anything new.
speedy_beedee is offline   Reply With Quote
Old 01-20-2011, 05:46 AM   #6
speedy_beedee
Member#: 181469
2009 Impreza GT
Sometimes the signals go crazy but it always fixes itself before I can get it to the dealer. The car has even stalled on me in traffic (automatic). The dealer never finds anything wrong.
Old 01-26-2011, 02:59 PM   #7
waness
Member#: 260995
2011 WRX STI Sedan
I had the same issue on my 11 STI. The bulb wasn't the problem...
The mechanic at the dealer told me the bulb wasn't making contact properly in the socket at that's what makes it blink faster..
They fixed it and I haven't had any problems since..
waness is offline   Reply With Quote
Old 01-27-2011, 11:20 AM   #8
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
oh noes...
must be a slow day.
anyone remember how quickly headlights burn out in 05-09 legacy and outback models?
Mavrik is offline   Reply With Quote
Old 01-27-2011, 03:21 PM   #9
joshjames
Member#: 233604
2011 WRX P.
Yep, I've got this. I think it is more the wire issue mentioned bu Subaru though. I though it was the bulb, but now the problem appears to be intermittent, which points elsewhere.
joshjames is offline   Reply With Quote
Old 01-27-2011, 07:57 PM   #10
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Originally Posted by Mavrik View Post
oh noes...
must be a slow day.
At 71k I am still on the original headlight bulbs
But yes i do..lol
Old 01-27-2011, 09:31 PM   #11
Mavrik
Member#: 90347
Yamaha FZ8
But yes i do..lol
guess you don't drive around lit like I do
Old 01-28-2011, 06:10 AM   #12
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Old 01-28-2011, 07:27 PM   #13
Supraru
Member#: 23313
99' 2.5Rs
black
Confused as to why you're complaining when you're covered under warranty. Take it in and get it replaced for free and they will check the wiring and make sure it's not routed wrong otherwise you'll still have this problem. If you are to lazy to take it into the dealer then don't complain. What is with these people seriously? I have yet to see a manufacturer make a perfect car with zero issues or anything going bad.
Supraru is offline   Reply With Quote
Old 01-28-2011, 08:31 PM   #14
arf80
Member#: 125580
2011 WRX 5dr
Luckily, I live in New Jersey and we don't use blinkers.
arf80 is offline   Reply With Quote
Old 02-02-2011, 12:08 AM   #15
G_REX
Member#: 266384
2011 WRX Limited
Spark Silver Metalic
when i took my car in for this issue the dealer wanted to take my bumper off to replace a harness .....I THINK NOT! Told them not to touch the car as it only take a tap to fix the issue. It's just poor connection....
G_REX is offline   Reply With Quote
Old 02-02-2011, 09:13 AM   #16
heavyD
Member#: 194216
2016 MK7 Golf R
Yeah unfortunately using turn signal to show other drivers your intentions of turning or changing lanes is a lost art. Nobody seems to use them up here either.
heavyD is offline   Reply With Quote
Old 02-02-2011, 12:23 PM   #17
Lboogie
Member#: 171611
2014 FiST
Blk
Maybe Subaru outsourced the turn signal engineering to VW/Audi.
Lboogie is offline   Reply With Quote
Old 02-02-2011, 01:25 PM   #18
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Damn, if they can't get you with the engine they screw you over with a bulb, eh?
Old 11-21-2011, 11:58 PM   #19
Entreri22
Member#: 301395
2008 WRX, Sedan
LOL
Entreri22 is offline   Reply With Quote
Old 11-22-2011, 10:39 AM   #20
ja697
Member#: 278007
2011 STI hatch
plasma blue
i got this issue also i got my PB sti hatch last march of this year. a week after i got her the right signal light was acting funny i think it was blinking fast. i found out that the front signal light right side was out. took it to the dealer and replaced the bulb. no problems up to now.
ja697 is offline   Reply With Quote
Old 11-22-2011, 10:52 AM   #21
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Warranty takes care of things like this....
jonklein611 is offline   Reply With Quote
So i know these are turn signal bulbs, but are they even legal? Thesystem3 Newbies & FAQs 9 10-01-2010 02:20 PM
turn signal bulbs so dim and ugly!! Rohrex Electrical & Lighting 16 02-07-2008 07:28 PM
did I just order the wrong turn signal bulb for my 05? DieselClown Electrical & Lighting 6 04-01-2005 02:43 PM
What size are the rear turn signal bulbs for the WRX? KillerRex Interior & Exterior Modification 3 07-08-2002 11:59 AM
