Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-01-2006, 12:04 PM   #1
summerandjoe
Member#: 98255
06 evo 9 mr
gg
Default PIN code?
i hooked up my alky kit over the weekend, and when i tried to access the maps i was asked for a PIN code. i had the car tuned a few months back and tried contacting the guy who tuned it. he is currently moving to a different location, so i have had no luck contacting him (along with a few other people). is there a way to bypass the PIN code, or a way to adjust the settings for spare solenoid?
summerandjoe is offline   Reply With Quote
Old 06-01-2006, 12:16 PM   #2
TheMadScientist
Member#: 23717
2005 Big red
If you have the map saved you can reflash the Utec firmware, that should get rid of the pin code. It will all so get rid of all the maps and parameters.
TMS
TheMadScientist is offline   Reply With Quote
Old 06-01-2006, 12:29 PM   #3
summerandjoe
Member#: 98255
06 evo 9 mr
gg
i don't have the map saved on my laptop. can i save it to my laptop without knowing the PIN code?
Old 06-01-2006, 12:39 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
I don't think you can. If you can't get to the Edit map screen with the maps listed you can't save them.
Your best bet is to get in touch with the tuner who set the PIN.
TMS
Old 06-02-2006, 01:17 PM   #5
summerandjoe
Member#: 98255
06 evo 9 mr
gg
got an email from the tuner today with the PIN code. thanks for the help, madscientist!
Old 06-07-2006, 10:30 AM   #6
TheMadScientist
Member#: 23717
2005 Big red
NP
You mind stating the shop that locked it? If not here then PM?
TMS
Problem with PIN Code HKS EVC-V cougar270477 Electrical & Lighting 0 05-17-2008 05:10 AM
getting hood put on, hood pins or no hood pins? azimiut Interior & Exterior Modification 2 05-10-2004 07:48 PM
How to get pin wire out of PIN conector? MooseWRX Electrical & Lighting 5 03-05-2003 03:53 AM
How to get PIN wire out from the PIN Connector? MooseWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-27-2003 12:11 AM
Pin code door locks Speedwagon Legacy Forum 0 08-02-2002 10:19 PM
