Old 06-01-2006, 12:22 PM   #1
JoshP
Member#: 94350
Default Which head gasket will be most reliable for 2.5 / 2.2 hybrid?
The thick gasket, the thin gasket or something else? Anyone? Going with stock 2.2 dual port heads, with the delta cams. Everything else is going to be stock. Phase II 2.5 block. thanks
JoshP is offline   Reply With Quote
Old 06-01-2006, 01:40 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
We just used the stock gasket for the phase I we did. They are all reputed to have been redesigned, but on my recent work I went with the STi gaskets. They are the same thickness as the NA phase II gaskets and a mulit-layer all metal gasket...
Old 06-01-2006, 08:07 PM   #3
shipjumper
Member#: 6307
what I has no car...
am carless
is there much gain from the dual port over the single port? We have some duals hanging around... but I was just thinking of doing a fast swap for the phase I block..
whats the CR difference from Phase I to Phase II with the 2.2l heads???
shipjumper is offline   Reply With Quote
Old 06-01-2006, 10:27 PM   #4
JoshP
Member#: 94350
actually, I do believe the single port heads would make more power on a 2.5 block personally. Bigger valves at least. Im using dual ports becuase they are easier to get my hands on, and im retaining stock exhaust. Compression comes out to about 12.5:1 with the thin gasket and 10.5? or maybe 11:1 with the thick gasket. With a phase 1 block you have to use the thick gasket though. I think thick is phase 1 and thin is phase 2 for the gaskets.
Old 06-01-2006, 10:33 PM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Not saying they are better, but I have found both aftermarket "OEM" metal gaskets and Subaru OEM metal gaskets. I have also seen ALOT of composite material gaskets. I would take the aftermarket metal gasket first, the subaru metal gasket second, and the rest last......
But I offer no proof.
Old 06-01-2006, 11:22 PM   #6
JoshP
Member#: 94350
cometic sells 2.5 gaskets but it only lists for Legacy 2.5 no year, considering that could be either Phase I or II
Old 06-02-2006, 10:57 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Just call Cometic. Before my headwork I ran their gaskets on my car. They cost about the same as the STi ones I am using now. But they do offer a couple of thicknesses and you just need to talk to them on the phone about it or e-mail them...
Old 06-02-2006, 12:20 PM   #8
JoshP
Member#: 94350
In their catalog it listed them at $45 a piece. Is that what STi gaskets go for? Becuase thats about the same price as n/a gaskets from the dealership.
Old 06-02-2006, 03:27 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
I am showing dealer list price on the STi gaskets at $40...
Hybrid 2.5 SB, 2.0 Heads 9vapors Built Motor Discussion 20 04-07-2007 12:04 AM
WRX Head/2.5 STi bottom Hybrid 12.92 @ 106.19 Ronin Quickblade Proven Power Bragging 8 05-25-2006 09:02 PM
Which head gasket for EJ257 swap SPESHAL Subaru Conversions 6 06-02-2004 12:34 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 11:08 AM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
