Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-01-2006, 04:10 PM   #1
marcus.raw
Member#: 97675
93 Stroked LS3 FD
Launch Edition 2015 STI
Default sti hid to wrx harness help?
hey guys, i tried searching and stickys and couldnt find any info on this. ive read in certain areas that either a harness has to be purchased or made to get this to work. it is an 05 sti bulb and ballast to an 05 wrx. can someone point me to the right direction on how to wire this correctly? wouldnt wanna blow one of these out =/
thanks
marcus.raw is offline   Reply With Quote
Old 06-01-2006, 04:13 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
So you only have the bulbs and ballasts and not the complete light assemblies? You can't just stick the bulbs into your factory halogen lights.
Old 06-01-2006, 04:18 PM   #3
marcus.raw
Member#: 97675
93 Stroked LS3 FD
i havnt got them yet, was planning on getting it, if i can figure out how to get them working. they wont fit into the wrx? i dont have the light housings if thats what your asking
Old 06-01-2006, 04:24 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Then don't get them. If you want the STi HIDs you have to buy the complete lights, which then bolt directly in place of your existing lights. You would have to do some wiring to get them working but it's well documented on this site and elsewhere.
The HID bulbs are D2R, your halogen bulbs are H1, they are not compatible physically and the D2R bulbs will not go in the H1 mounts. The reflector design in the light housing is also different for the HIDs, even though they look very similar, so even if you somehow were able to install the bulbs the beam pattern would be terrible.
Old 06-01-2006, 07:23 PM   #5
marcus.raw
Member#: 97675
93 Stroked LS3 FD
thanks
Old 06-02-2006, 07:13 AM   #6
Okita Souji
Member#: 41097
2005 WRX
Actually the reflector housings are pretty much the same. However, the bulb shield in the middle is different. The STi ones have raised sections on both sides to prevent glare.
Okita Souji is offline   Reply With Quote
Old 06-02-2006, 08:47 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you compare the reflectors side-by-side very carefully, they are indeed different. Not dramatically, but enough to make the beam pattern suitable for the respective bulb types used with each one.
Sti HID install with harness? theomms Interior & Exterior Modification 0 08-18-2009 09:37 PM
Need help with wiring in 05 STI headlights to 07 harness Samurai_jim Subaru Conversions 0 01-19-2009 11:32 PM
2007 STI HID Headlights, Relay Harness, and Leveling Switch spincycle Exterior/Styling 11 10-19-2008 07:53 PM
FS Socal: Bugeye 02-03 JDM STI HID Headlights, Custom Harness, Leveler sbrcr267 Exterior/Styling 7 05-07-2008 09:21 PM
Were I can Find or Buy a STI HID headlight adapter harness? thunderay Interior & Exterior Modification 7 10-23-2005 04:03 PM
