Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-01-2006, 08:09 PM   #1
Kenzo41587
Member#: 112842
2001 Impreza 2.5 RS
Default Utec Abc
Bought a UTEC and it did not come with a ABC Y piece or a ABC.
I read some threads where you do not need to have this installed, but the guy was seeing some boost spikes and knock problems.
Will the UTEC be able to control boost without the ABC or do I need to go out and buy one.
Also, is it safe. Thanks
Kenzo41587 is offline   Reply With Quote
Old 06-01-2006, 08:10 PM   #2
Kenzo41587
Member#: 112842
2001 Impreza 2.5 RS
Oh also it didn't come with a 9v adaptor, how else can I power it up. THanks
Old 06-01-2006, 09:15 PM   #3
subwrx03
Member#: 96290
2003 Jetta wagon TDI
blue
mine didnt come wit 9v ethier i went to radio shack with the utec and they made one up for me works perfect!!!
subwrx03 is offline   Reply With Quote
Old 06-01-2006, 09:18 PM   #4
Kenzo41587
Member#: 112842
2001 Impreza 2.5 RS
Hah that is just what i'm about to do. Thanks!
Old 06-02-2006, 11:51 PM   #5
VWGrk1
Member#: 57882
2004 WRX
Regarding the ABC: You could just upgrade to the GM BCS and enjoy quicker spool as well as not needing the ABC anymore. $50, IIRC, which is cheaper than an ABC.
VWGrk1 is offline   Reply With Quote
Old 06-03-2006, 11:59 AM   #6
2phless
Member#: 69343
1998 TransAm cnvrtbl
I run the GMBC and a TurboXS Dual stage BC for some on-the-fly flexibility. Their DSBC is designed in a similiar, bleed-off manner to the ABC, inline instead of t'd... But I don't even need the first stage with the GMBC.
The ABC wouldn't be a fix for spiking or knock, it'd only hurt that if it were installed and opened up any. Closed it's 'invisible'. Those issues need to be tuned out. Raising the UTECs gain setting to lower spikes, and reading the heck out of Mick-the-Ginge's PDF on tuning for the knock, should those arise.
And the T fititng for the ABC can be replaced with any T fitting from the parts store.
2phless is offline   Reply With Quote
Old 06-04-2006, 01:53 AM   #7
Kenzo41587
Member#: 112842
2001 Impreza 2.5 RS
Thanks everyone for the information!
UTEC ABC Adj.? XS_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-13-2004 01:09 AM
UTEC ABC "Y" size JAUNE Engine Management & Tuning 2 07-31-2004 05:23 AM
TXS Stg4 UTEC ABC Tuning jetskizero Engine Management & Tuning 5 09-13-2003 11:11 PM
UTEC ABC wont move boost 1FastREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-22-2003 09:14 PM
UTEC ABC used as an MBC? eingram Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-25-2003 10:15 AM
