Welcome to the North American Subaru Impreza Owners Club Tuesday September 23, 2014
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-01-2006, 09:02 PM   #1
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Default Hydra Air Temp Trim Question...
Any of you guys use the air temp trims sugjested in the MR2 Hydra "tuning guide"?
Right now I've got (from -20C to 130C):
4.1 : 3.6 : 3.1 : 2.5 : 1.9 : 1.3 : .6 : 0 : 0 : 0 : .1 : -.4 : -.9 : -1.3 : -2 : -2.5
And the values he sugjests are:
12.7 : 12 : 10.6 : 8.4 : 5.6 : 2.5 : -.6 : -3.2 : -5.7 : -8.1 : -10 : -11.1 : -11.6 : -12 : -12.3 : -12.5
These values seem very differant from one another, so I thought I'd get some input from some other folks before I start using them... or mabe I will say screw it and try them anyways, but I basically want what will give me the most consistant AFRs.
Nick
Sko is offline   Reply With Quote
Old 06-01-2006, 11:53 PM   #2
Sko
Member#: 90396
2005 Legacy 2.5i
Another question I am asking only to have to come to my own conclusions.
After testing those settings it really leaned out my AFRs at idle, and didn't attempt driving around with those settings, if anyone did get them to work however it would be nice to know how well they do work.
Of course my car came stock with a MAP sensor and not a MAF so the intake air temps might be off by a little bit.
Nick
Old 06-02-2006, 10:15 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Sko,
You cannot use the IAT settings for the MR2 as they are based on the GM IAT and with a corresponding base map.
This is not an area you should concentrate your efforts on. First tune your fuel map and make note of your IAT temps while tuning. If you think for whatever the IAT correction table is off as IAT temp changes under driving conditions then you can modify the table to ensure you are hitting the same AFRs.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-02-2006, 08:26 PM   #4
Sko
Member#: 90396
2005 Legacy 2.5i
Ah, makes perfect sense.
Thanks Phil!
Nick
Air temp reading -4*F and overheating w/ HYDRA tenchu Other Engine Management 17 06-08-2010 02:53 PM
Changing air temp sensor with a Hydra gumby647 Other Engine Management 4 03-26-2009 08:10 PM
trying to find air temp gauge. before-after intercooler air temp, and two others STEALTH-WRX Factory 2.0L Turbo Powertrain 6 06-10-2003 03:38 PM
Help finding Intake Air Temp or Coolant temp sensor jacksonww Legacy Forum 1 08-27-2002 01:42 PM
Question about air temps. Tkacik Normally Aspirated Powertrain 10 07-05-2001 09:32 AM
