Old 10-12-2001, 08:04 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Question Getting the 2.5 block apart
ok, all that is left to my block is the super liquid gasket between the two block halves. Anyone know what tool to use to pry these 2 apart or any specific technique to use? Thanks,
-Eric
smacksube is offline   Reply With Quote
Old 10-14-2001, 10:23 PM   #2
smacksube
Member#: 4067
01 2.5 rs
anybody.....? -bizump-
Old 10-16-2001, 05:50 PM   #3
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
ahh..I would say, don't pry it with a small flat head. Try using something thin, wide and strong to pry it open with. Or if you want to bang on it, use a brass or wooden hammer. I guess it depend on what exactly the case looks like, and where there are areas on the case you could smack with a hammer that would help loosen the glue stuff. Good luck!!
-Andy
RallyImprezive is offline   Reply With Quote
Old 10-17-2001, 01:45 PM   #4
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Are you sure it is ready to come apart? There are 6 hidden case-bolts in the water jacket that are often overlooked.
At the dealership they have some brackets that bolt to the motor-mount hole on the block, these are what you should hit with a hammer to seperate the halves. If you hit on the aluminum block with even a soft-face hammer you risk deforming the aluminum.
SubyTechMaster is offline   Reply With Quote
Old 10-17-2001, 10:06 PM   #5
smacksube
Member#: 4067
01 2.5 rs
yah, I got the water jacket bolts....a real bitch to get at too, 12 point 12mm on a 3/8" extension....kinda not standard. I broke one extension off in the jacket and had to buy a even more heavy duty one. I have avoided doing anything to the block that risks deforming the aluminum, but I'll pop down to the dealership and see what the deal is on those parts. Thanks alot.
-Eric
I've read the 2.5 block/pistons are good for 450-500 (how true I don't know) wrxej205 Newbies & FAQs 41 07-10-2009 03:47 PM
So New Zealand gets the 2.5 litre (liter) STI STiMULi General Community 0 12-10-2005 10:44 PM
Boring out the 2.5 block? 0260B4U Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-05-2004 01:08 AM
RS 2.5 block and STi 2.5 block Rancid General Community 4 01-26-2004 07:57 PM
2.0 to 2.5 block swap, what's the ideal Compression ratio? 516_WRX_V2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-25-2003 12:44 AM
