Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 10-12-2001, 09:28 PM   #1
93preza
Member#: 11030
1993 Impreza L
White (1.8 to 2.2 soon)
Default 1.8 to 2.2 engine swap
Just wondering how difficult and what I would need to do to swap a 1.8 for a 2.2 for a '93 Impreza L. Also, how beneficial would it be? If anyone could help me in general finding performance mods for my car to get the thing around 200 HP (that's my goal) that would be helpful.
Thanks!
93preza is offline   Reply With Quote
Old 10-13-2001, 02:46 PM   #2
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
It should be a direct swap, depending on what transmisssion setup you want to have. I think that the FWD and AWD transmissions should both link up with no problems...Thats what I have been told. I am looking to perform this swap in the future.
Tkacik is offline   Reply With Quote
Old 10-13-2001, 06:37 PM   #3
mile hi
Member#: 6129
1995 coupe
green metalic
Default 1.8 to 2.2 swap
I have done the swap it's not bad but I got carried away and went for the 2.2 turbo and had to change the front crossmember also. The rest is almost bolt in. What I did is use the 1.8 harness from the engine to the ECU the pins on the green or blue ECU plugs will fit into the yellow plugs on the '94 turbo Legacy ECU and all that is needed then is one more small plug and a few additional wires for the knock sensor and turbo control and it works great it started on the first try. Al(CO)
mile hi is offline   Reply With Quote
Old 10-14-2001, 03:13 PM   #4
Tkacik
Member#: 847
'06 Titan Crew Cab
Thanks for the wiring info. That is one of the spots that I thought that I might encounter problems.
1.8 to a 2.2 swap? notasubyguy Normally Aspirated Powertrain 26 01-31-2009 11:57 PM
95 1.8 to 98 2.2 swap jahwarrior007 Subaru Conversions 2 10-24-2008 08:34 PM
1.8 to rebuilt 2.2 drewdogg Subaru Conversions 34 07-11-2005 10:41 PM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
1.8 to STi 2.0 swap... need some help. wagman01 General Forum Archive 5 02-21-2001 09:57 PM
