Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 06-02-2006, 05:46 PM   #1
JSC Speed
Vendor Sales Rating: (72)
Member#: 75126
Default GOT CROWER CAMS and RODS? <------------ <----------- <---------- <-------------
GOT CROWER CAMS? WE DO- INSTOCK- PM OR POST FOR PRICES
Scroll Down For CROWER Rods!!!
Crower Cams and Valvetrain Kit for 2002-2005 WRX EJ20
Stage/Description:
STAGE 1: Street use with emphasis on bottom end and mid range power. Works with stock springs up to factory rev limiter.
RPM Range: Idle to 7000+
Advertised Duration (Seat): Int: 256o / Exh: 256o
Duration @ .50": Int: 216o / Exh: 216o
Gross Lift: Int: .380" / Exh: .380" (9.65mm)
STAGE 2: Best cam choice for daily driver. Delivers excellent top end without loosing low end torque. Recommend spring kit #84185.
RPM Range: 1000 to 7500+
Advertised Duration (Seat): Int: 264o / Exh: 264o
Duration @ .50": Int: 220o / Exh: 220o
Gross Lift: Int: .400" / Exh: .400" (10.16mm)
STAGE 3: Designed for street/strip applications and features a slight lope at idle and great top end power. Requires spring/retainer kit #84185.
RPM Range: 1250 to 8000+
Advertised Duration (Seat): Int: 272o / Exh: 272o
Duration @ .50": Int: 228o / Exh: 228o
Gross Lift: Int: .406" / Exh: .406" (10.31mm)
STAGE 4: Drag Race and radical Street/Strip. Requires #84185 spring kit and compatible ECU upgrade for optimum results. Rough idle. Requires spring/retainer kit #84185.
RPM Range: 1500 to 8500+
Advertised Duration (Seat): Int: 280o / Exh: 280o
Duration @ .50": Int: 234o / Exh: 234o
Gross Lift: Int: .415" / Exh: .415" (10.55mm)
VALVETRAIN KIT: Reccomended for Stage 1, required for Stages 2-4, includes 16 springs and 16 titanium retainers.
SPRING SPECS: Seat: 1.420" @ 60 lbs / Nose: 1.000" @ 161 lbs / Coil bind: 0.860"
Crower Rods for WRX/STi/LGT:
Crower billet steel Subaru rods are some of the strongest on the market. Made from 4340 chromoly steel, the I-beam design of Crower rods eliminates excess material and gives uniform strength through the entire piece. Center to Center: 5.141", Big End Housing Bore: 2.166", Big End Thickness: .843", Pin End Bore: .905" (23mm), Pin End Width: .843".
FITMENT:02-05 WRX EJ20 & 06+ WRX / 04-06+ STi / 05+ LGT EJ257
JSC Speed is offline
Old 06-02-2006, 05:49 PM   #2
InfamousDX
Member Sales Rating: (184)
Member#: 25413
Anything that will work with an ej207 head?
InfamousDX is offline
Old 06-02-2006, 06:07 PM   #3
michaeldover
Member Sales Rating: (9)
Member#: 95272
2006 WRX tR
What supporting mods will I need to do the Stage 4 Cams + valvetrain. Can I also get price on that stuff? And also stage 3 Cams + valvetrain. Thank you!
-Mike Dover
michaeldover is offline
Old 06-03-2006, 07:32 AM   #4
tino
Top Scoob 019
Member Sales Rating: (2)
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
are these AVCS compatible? can u get different combinations for the inlet and exhaust?
tino is offline
Closed Thread
Anyone running Crower cams? Antonios Kintos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-19-2005 01:14 AM
crower cams Antonios Kintos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-17-2005 11:37 PM
would WRX crower cams work? one wicked wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 03-08-2005 12:12 PM
will crower cams work one wicked wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-02-2005 05:54 PM
