Old 06-02-2006, 05:39 PM   #1
fenix_black
Member#: 112180
05 2.5 RS
Question What is this?
Does anyone know what this hose is for?
close-up
fenix_black is offline   Reply With Quote
Old 06-02-2006, 05:40 PM   #2
JohnBlaze74
Member#: 24929
08 SPEC.B DGM
i think your talking about the heater core lines??? may be wrong
JohnBlaze74 is offline   Reply With Quote
Old 06-02-2006, 05:42 PM   #3
fenix_black
Member#: 112180
05 2.5 RS
It is clamped to the drivers side of the stock air box
Old 06-02-2006, 05:44 PM   #4
richard donovan
Member#: 62738
2000 RS,5MT,Silver
DeltaCams,Borla,Prodrive
the heater core lines are below that and back toward the fire wall... can see them in the picture, where does the line go? crank case breather line....there is one on the other side also both of them run to the valve covers.
richard
correct me if i'm wrong.
richard donovan is offline   Reply With Quote
Old 06-02-2006, 05:45 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
cylinder head oil vapour breather hose. Why do you ask?
Old 06-02-2006, 05:49 PM   #6
fenix_black
Member#: 112180
05 2.5 RS
now this leads me to my next question...
I got an intake here a friend bought for his car... however it was not designed for his car because it has a spot for the MAF sensor. He wasn't a careful ebay shopper haha so he asked me if I wanted to buy it from him for cheap and I'm trying to figure out if it will fit. I don't see anywhere to attach this line to it though... any ideas?
thanks for the quick replys!
Old 06-02-2006, 05:56 PM   #7
fenix_black
Member#: 112180
05 2.5 RS
The intake appears to be an injen clone and I don't see a bung for that line on the real injens for the 05's either...?
Old 06-02-2006, 06:22 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
If there is no bung, the easiest thing to do is get some more hose and some connectors and "T" it into the crank breather or the other head breather line before it enters the intake. You just need to be sure that the system is closed and doesn't cause a vacuum leak.
Or, if you want something that looks "cool" you can get mini K&N filters for both head breathers and do away with all of the plumbing from the heads. I have seen this done on turbo cars before...
Old 06-03-2006, 09:56 AM   #9
fenix_black
Member#: 112180
05 2.5 RS
thank you much matt! just what i was looking for
Old 06-03-2006, 10:26 AM   #10
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
Wait i'm confused so is it for an 04 and below RS or an 05+ RS, because if its an intake for anything 04 and below its not gonna fit with out some cut n rewelding, cause the maf sensors are completely different.
Caplin 2.5 is offline   Reply With Quote
Old 06-03-2006, 02:59 PM   #11
ScoobyDoobieBlue
Member#: 71509
2000 Subaru 2.5RS
BRP
Oh noes all of mine are open, that must be bad mmmkay.
ScoobyDoobieBlue is offline   Reply With Quote
Old 06-08-2006, 04:57 PM   #12
fenix_black
Member#: 112180
05 2.5 RS
well the intake fit but now i'm not so sure I like it... It is still almost stalling when coming to a stop (i did reset the ecu) and now it sounds like i have valve tick... which I never had before.... bad tank of gas??
Old 06-08-2006, 06:59 PM   #13
fenix_black
Member#: 112180
05 2.5 RS
now I have a CEL and the "cruise" light is blinking......
what is this part called? what is it's part number? OUScooby Private 'Wanted' Classifieds 8 04-21-2010 04:08 PM
What is this connector, and why is it unplugged?? Kwyjibo Electrical & Lighting 7 09-24-2003 01:21 AM
What is this part in my fuel system. Can I remove this STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-06-2003 12:07 PM
what is this? is it a good deal? coilovers cheap? mcu81 Tri-State Area Forum 17 01-01-2002 11:24 AM
('93-'01) what is this and what does it do? shimstock Impreza Forum 4 04-10-2001 09:53 AM
