Old 06-02-2006, 10:13 PM   #1
elmo3
Member#: 60601
Default Need help - Clutch problem; weird noise and feeling
Could someone offer their advice?
I have a 04 TS wagon.
When my clutch pedal gets close to the floor, I'm getting a strange resistance feeling. At the same time, I can hear a rubbling noise and squecking sound. The resistance feeling is constant when you let the clutch pedal up. It only happens when the clutch is an inch or two off from the bottom.
I could hear a knocking sound under the engine bay area.
There's no problem with shifting gears or engaging the clutch from a complete stop.
Thanks for your help..
elmo3 is offline   Reply With Quote
Old 06-10-2006, 03:48 PM   #2
vintage
Member#: 88987
2002 Impreza
I fixed that problem with a new slave cylinder and also make sure the rubber cover sit in the right position because when the fork move it will make noise if not. ( the one push by the slave cylinder )
when I got the new slave cylinder I pushed the rod I felt that the pressure is double with my old one.
vintage is offline   Reply With Quote
Help. Engine makes weird noise (with vid) GC84ever Normally Aspirated Powertrain 5 03-21-2007 10:11 PM
help! gettin a weird noise...... devs05wrx Tri-State Area Forum 10 02-26-2007 09:17 AM
need help with a weird whining noise..... crosta21 Service & Maintenance 10 05-16-2006 02:25 PM
Weird noise and LOTS of power loss HondaDestroyer Newbies & FAQs 6 04-18-2006 04:08 AM
Help... Clutch making awful noises... Siper2 New England Impreza Club Forum -- NESIC 34 02-26-2004 09:41 AM
