Old 10-12-2001, 11:20 PM   #1
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Default Drain plug thread size???
Does anybody know the thread size of the drain plug on my 01 2.5RS? I need to find an adaptor for my AUtometer oil temp sender. Thanks.
LVSUBARU is offline   Reply With Quote
Old 10-12-2001, 11:36 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I wouldn't take the temp from the oil pan...take it from the block.
If you look at the block, directly in front of the oil pan, there are 2 12mm allen bolts approx. 4-5 inches apart. They have the same thread as the oil pan, but the reading will be much more accurate, and won't fluctuate as much. I found that mine would cool down when the car was moving and there was airflow over the sensor and front of the oil pan, then shoot back up when I stopped moving.
Impreza Rider is offline   Reply With Quote
Old 10-13-2001, 01:26 AM   #3
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
So what's the thread size on those allen bolts? Where did you get your adaptor???
Old 10-13-2001, 01:30 AM   #4
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I had the Subaru preformance pakage that had it. That's where my sender came from. Sorry, but I don't know the thread pattern for it AN-8 sounds familar...but I'm only about 50% positive about that.
03 wrx oil drain plug thread size edogg6565 Service & Maintenance 1 04-16-2010 11:34 AM
Oil drain plug thread size? shemoves Service & Maintenance 3 10-07-2005 01:14 PM
oil drain plug thread size? vile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-22-2003 10:59 AM
Oil Drain Plug Thread Size daytontp General Community 10 01-04-2002 11:35 AM
Drain Plug Thread Size Marquis Normally Aspirated Powertrain 3 02-16-2001 11:25 AM
