Old 06-03-2006, 11:35 PM   #1
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
Default Meth specific question....any chemical engineers out there?
The place that I have been getting my Meth from has a small amount of lube blended in.
i am running 50/50 mix, how much does this lube affect my engine and pump? i use a SMC pump, and 10gph nozzle.
if you need specifics on what brand meth and how much %lube, i can get that on monday.
banzai is offline   Reply With Quote
Old 06-04-2006, 12:29 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....fergetaboutit....non issue
Old 06-05-2006, 02:22 PM   #3
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Probably top lube, used to keep alky engines (the ones running pure meth) healthy and happy. You can probably ask for the "straight meth" and they will be happy to supply it. Adding the top lube just adds cost to your supplier.
There is probably no problem running the top lube, but I wonder just how compatible it is in a water mixture. It also reduces the octane ever so slightly.
bcblues is offline   Reply With Quote
Old 06-05-2006, 07:55 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
also you have to consider the bouyance of water / meth / lube.
and how to keep the solution homogenous to ensure a uniform
distribution of all the liquids in the solution.
have you had your car tuned yet?
what where the results with the 10 gph nozzle?
do you have any larger ones?
why do I ask?
Well I was tuning an 06 STi with a 10 gph nozzle
and did not see numbers that were advertised.
Ben
Old 06-05-2006, 09:27 PM   #5
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Send SMC an email.
PeteDucati is offline   Reply With Quote
Any Industrial Engineers out there? wakeboarder109 Mid Atlantic Impreza Club -- MAIC 9 01-15-2008 09:35 PM
Any Mechanical Engineers out there? 5spdfrk Off-Topic 79 01-11-2006 02:29 PM
Any auto engineers out there? wrxsubaru Off-Topic 7 09-27-2004 09:33 PM
Any Electrical Engineers out there? ursine Electrical & Lighting 16 02-04-2004 06:58 PM
OK Igg, Idjiit, and any mechanical engineers out there.... -=C=- Off-Topic 23 08-01-2003 03:21 PM
