Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 06-04-2006, 07:00 PM   #1
Member#: 87747
2008 WRX
Dark Grey Metallic
Default center tach set up into an 02 TS? help anyone?
does anyone know if a gauge cluster that has the center mounted tach and right side spedo will plug n' play in a 02 TS? I'm looking to buy one but wasn't sure if it'll hook up with the existing setup. thanks.
legacyvt286 is offline   Reply With Quote
Old 06-04-2006, 10:24 PM   #2
Member#: 75744
2k2 low boostin
evo3, for now....
the 04 wrx cluster fits into a 02 wrx just fine. it should work with you too. but your miles will be wrong then, just a FYI
taerron is offline   Reply With Quote
The Write-up. How To Retrofit FX35 Projectors Into an 02-03 Bugeye jdubya301 Electrical & Lighting 256 02-02-2012 08:03 AM
06 5spd WRX tranny into an 02 WRX??help chperformance Transmission (AT/MT) & Driveline 11 02-11-2010 11:27 AM
Can a suspension set up for an 02 WRX sedan fit on an 02 WRX wagon? 95 avus blue Brakes, Steering & Suspension 3 11-05-2005 08:48 PM
Just how much stuff, can you stuff into an impreza TS wagon.... pleiades South East Region Forum 13 10-14-2004 07:51 AM
Jacking up an 02 TS issue Brighton Service & Maintenance 4 10-01-2004 04:50 PM
