#1 |
Member#: 3607
Vehicle:98 Impreza RS black |
does press bend and mendral bend pipings for intercooler
make any difference? (front mount)
#2 |
Member#: 1911
Vehicle:2000 Impreza 2.5RS Silverthorn Metallic |
If smooth flow matters, you don't want press/crush bent pipes. So, yes. If you are going to invest all the money and effort in a front-mount intercooler, why cut corners?
Ben |
#3 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
i agreel, mandrel bent is the way to go for free flow thru the intake...turbulence is bad and caused by kinks in the piping.
Jeremy |
#4 |
Sea to Sky - OWNED
Moderator Member#: 610
VIC
Vehicle:2003 Lexus IS300 Graphite Gray Pearl |
Mandrel all the way...something as important as an intercooler (a front mount no less!) should have as smooth airflow as possible.
#5 |
Member#: 9422
Vehicle:2002 silver wrx R.I.P. |
***newbie question alert
***whats the difference between the two bends? |
#6 |
Member#: 1911
Crush bending just involves clamping the pipe and bending it. Crush bends generally put kinks in the pipe which cause turbulence in whatever flows through it. Mandrel bending uses a round plug (a mandrel) inserted into the pipe and moved along within the pipe to always be at the point being bent. This keeps the inside of the pipe smooth through the entire bend.
Might I suggest making use of a good search engine ( like Google ) in the future? You will be able to answer just about any question you have much more quickly. Ben |
#7 |
Member#: 3768
Turbulence in Intercooler piping heats the air marginally. I went with mandrels. I dont think I've ever seen pinch bent intercooler piping! Hopefully I never do!
adamsrs www.unnatural.org |
#8 |
Member#: 3607
I need help guys, I am so stuck...I have a front mount Intercooler
sitting in my house with no pipings for my turbo kit... and I just asked to make a mandrel bent piping for front mount cost 2000$ CDN ....and I can't affort that much...just for piping is 2000$...so is it better that I sell my IC and get top mount intercooler instead? if anyone wants to sell their top mount IC for minnam kit please let me know.....=( also looking for HKS seq. blow off valve as well. thanks. |
#9 |
Member#: 4106
what kinda FMIC do you have ? I'm getting my front mount this week and also have my top mount spearco for sale including a greddy BOV and turbo-IC ceramic coated pipe. give me the dimensions for the core you have and also the maker.
BTW , all you need is to buy mandrel bend (U-bends)/hoses/clamps and get someone to your garage with a pipe cutter and tig welder and the piping should be done in a day or two. zaidoun |
#10 |
Member#: 3607
my front mount intercooler i got it free from a friend, which is
used and don't think has brand name on it... not sure the dimension..but it's not big thats all I can say... but how much are you willing to sell ur top mount? |
#11 |
Member#: 4106
well I got a couple of guys ahead of you wanting to buy it , I will not sell it till my engine is ready in a couple of weeks. it'll be $500 for the polished IC / greddy BOV and ceramic coated turbo/ IC pipe. the IC is not as wide as the minnam but thicker and flows as much air and charge temp stayed good even at 12 psi on a larger turbo than the minnam one. pm me if want to call dibs if you don't mind waiting.
zaidoun |
#12 |
Member#: 2958
NWIC
Vehicle:2001 WRX (GC8) |
I doubt you are running very much boost on a Minnam kit. Here is what some of the DSM people have done. Go to a place like Jeggs or Summit racing and buy sections of Mandral bent exhaust pipe. Try to figure out what bends you need. The pieces are generally ~$10USD each depending on size and bend type. Then buy Silicone connectors to hook it together. These pieces can be expensive but you can do it for a lot less than $2000CDN.
Give it a shot. If you want, later you can get a shop to replace the pieces of silicone with more pipe and weld it in. Will not look like a perfect piece, but who cares... function over looks. ![]() Jeff |
#13 |
Member#: 3607
I wouldn't mind do the custom piping myself but
my fron IC has to modify as well I don't know...I will think it over... what other shop or manufacture makes top mount for RS that will fit with the minnam kit? |
| Thread Tools | |
| Display Modes | |
| Does anyone have the spec sheet for the front mount intercooler piping | 20SilverSti05 | Factory 2.5L Turbo Powertrain | 0 | 07-08-2009 12:51 AM |
| Intercooler hoses, STI/WRX what’s the difference? | Gatchaman | Factory 2.5L Turbo Powertrain | 3 | 03-26-2007 08:49 AM |
| Intercooler on top or in the front? What is the difference? | efnikbug | Impreza Forum | 7 | 01-01-2004 05:02 PM |
| What's the difference? Cheap up-pipe or expensive up-pipe? | Rallye-fan | Factory 2.0L Turbo Powertrain | 2 | 03-26-2003 01:19 AM |
| what is the difference between a jdm and usdm midpipe/center pipe? | Benjamin Tang | Factory 2.0L Turbo Powertrain | 0 | 01-19-2003 08:04 PM |
