![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
In the silly seat
Moderator Member#: 34935
Vehicle:SPB- 2013 Smugmobile |
The wagon started using oil last week. We went through about half a quart on our drive up to PA, which is 200 miles. I had to keep feeding her to make it through the weekend.
- There is no oil leaking anywhere in the engine bay, oil pan, oil filter area, or anywhere else I can see. - There is no smoke from the engine bay. - There is no smell. - There is no smoke coming from the exhaust that anyone noticed over the weekend. I took the following pics of the turbo outlet today when I pulled the TMIC: ![]() ![]() A wipe inside the turbo outlet with a paper towel: ![]() Have the seals gone in the turbo? What else can I check?
#2 |
Member#: 55541
Vehicle:05 OXT KB3UIW |
That doesn't look too terrible considering the mileage.
#3 |
Member#: 24956
Vehicle:1997 Impreza WRX Steel Blue Mica |
No, that looks about normal. You better just swap a V7 drivetrain to cover all your bases.
#4 |
Member#: 24308
Vehicle:Oh, **** it I'm gonna have a party |
How did you catch loss of oil over only 200 miles? do you check your oil every ten minutes!? Oh nevermind I think I misread.
very suprising to have a bad turbo seal and not see smoke out the back. Have someone folllow you and get on the gas. |
#5 |
Member#: 96951
Vehicle:2004 wrx sedan 1996 brighton coupe |
how many cats are still in place? im thinking if all 3 are still there, they might be able to burn off all the oil smoke if its being leaked from the turbo.
oh, and since youre home, put some cardboard under the car overnight to check for leaks you might have missed. Last edited by nkx; 06-04-2006 at 11:57 PM. |
#6 |
Member#: 115715
Its how you hump your car.
#7 |
In the silly seat
Oil was full when we left MD and oil was down 1/2 quart when we were leaving PA the next morning.
The car is catless. We had people following us all weekend at STPR and no one reported any smoke. |
#8 | |
In the silly seat
#9 |
In the silly seat
So yeh, this sucks.
#10 |
Member#: 6590
Is the back of the car covered in an oil film?
#11 |
Member#: 64805
Vehicle:2008 SG6 Model D BlueRallyWorld |
You should grab a catch can for good measures...but that is still a lot of oil. Maybe one of the "oil gremlins" snuck under you hood when you weren't looking:
![]() NOTE: They are indigenous to MAIC and are closely related to the "Right Sock Gremlin" who is also from this area. |
#12 | |
In the silly seat
I'm confused. |
#13 |
Member#: 27541
Vehicle:0000 Pickup truck & Mountain Bikes |
PCV Valve?
#14 | |
In the silly seat
I didn't even know what it does...it can leak/cause me to use that much oil? |
#15 |
Member#: 78041
Vehicle:95 L '02 WRX Wagon '06 Silverado 2500 |
I think that we're not getting accurate readings on the oil level. Each time it was measured it was at a different temperature...
#16 | |
In the silly seat
#17 | |
Bonkers status: Clonked
Super Moderator ![]() Member#: 7977
Vehicle:100% Abuse |
#18 | |
In the silly seat
#19 |
Member#: 27541
Hrm, to use 2 quarts via PCV would be impressive, but not impossible. Last time my car was using a lot of oil it was due to stuck piston oil rings, but I had a fine black powder all over the back of the car which was all carbon from burning up the oil. PCV is cheap and pretty easy to replace, just be sure to use a Subaru OEM one, not aftermarket. The aftermarket ones I've seen are pretty sucky and don't really do a good job.
-Tom |
#20 | |
Member#: 6590
#21 | |
Member#: 24888
#22 | |
In the silly seat
I was letting it cool as much as possible...most times measurements were taken first thing in the morning with the car sitting overnight. |
#23 | |
Member#: 6590
| Thread Tools | |
| Display Modes | |
| FS: Used shortblock, stock turbo, big TMIC- | rickeolis | Engine/Power/Exhaust | 2 | 08-24-2007 10:47 AM |
| Can 2.5 rs owners use the stock turbo kit from a 02 wrx? | OutkastWRX2 | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 07-20-2004 11:17 PM |
| Anyone is using an Apexi turbo timer in their STi? Does it work with the stock alarm? | JDM addict | Electrical & Lighting | 6 | 09-17-2003 01:48 PM |
| 6,000 miles and my STi is using oil, THIS IS BS!!!!! | SilverSTi | STi Forum Archive | 72 | 07-16-2003 06:25 PM |
| Engne is using oil Again! | RallyeX | General Forum Archive | 7 | 06-17-2000 08:25 AM |
