Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 06-05-2006, 12:33 AM   #1
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Smile Port & Polish for the ProTune!
I've never P & P'd anything in my life, but after reading 'P & P Madness' and a few other things, I think I'm ready to try a couple of things...
First, I'll do my IC inlet elbows. Cheap part, probably easiest to do. Will be good to 'learn' on. Probably no gains but everything helps!
If that goes well, I'll do my throttlebody inlet. It looks easy as well, and is reputed to be quite an effective mod.
I'll drive that around for a week or two, and if the spirit moves me, I'll do my exhaust manifolds and crosspipe. The consensus is that doing these have a noticeable effect on spool and responsiveness. While I have them off, I may as well give the manifolds a DIY thermal coating. The crosspipe being stainless instead of cast, I'll remove the heat shield, coat it, and replace the heat shield.
So, I'm looking for a cheap die-grinder (I have access to a compressor) and some cheap bits/wheels/stones. I saw a Coleman one at Wal-Mart for about $30, Cdn Tire about the same for a cheap JobMate.
I'm gonna look at Princess Auto, but where else could I get the consumables for a reasonable price? House of Tools?
If anyone's interested, my shop has a huge compressor with two hoses. So...I could host a little thing if anyone wanted. Experienced Port & Polishers would be very welcome!
So, yeah, where can I get cheap/good abrasives?
Does anyone have spare OEM exhaust manifolds + crosspipe for an 02 sitting around? It would be better to do it on 'spare' parts, then I just have to swap = less down time!
Here's the P&P thread that got me going!
http://forums.nasioc.com/forums/show...ht=port+polish
02WHITEDUB is online now   Reply With Quote
Old 06-06-2006, 07:56 PM   #2
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Wow, I'm surprised nobody seems interested in an effective, 'free' mod (except for the abrasives.)
I'll post some pics and impressions here anyways - when I'm done.
I fear that doing this will be VERY time-consuming, with noticeable but not amazing results. I figure the hours spent versus the improvement will be a sad, sad ratio. I'll still do it though...and let the dyno tell the story!
Old 06-06-2006, 10:00 PM   #3
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
If you're going to P&P your OEM manifold you may want to buy an Injen crossover pipe to go with them. Our stock crossover pipes are pretty thin so you can't really do anything with them.
FWIW I have a P,P&TC'd OEM exhaust manifold. There's a thread in the 2.5L forum that'll show you your time on the header is worth it.
-J
Jitenshakun is offline   Reply With Quote
Old 06-06-2006, 10:07 PM   #4
02WHITEDUB
Member#: 96793
02 ProTuned TD04
I've seen a couple crosspipes that people here have coated, heat-wrapped, and replaced the heat shield. That would increase the effectiveness of the stock part enough for me, I think.
Old 06-06-2006, 10:37 PM   #5
Jitenshakun
Member#: 61586
2005 STi
When you see how restrictive the manifolds are you'll wanna P&P 'em. They're really short so if you have a decent compressor and a couple bits from crappy tire you'll be pretty happy.
On a 2.5L (untuned) you can get about ~10 whp & 15 wtq (dyno "proven").
-J
Old 06-07-2006, 11:51 AM   #6
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Yeah, I removed one for my UP and EGT install. They're pretty nasty inside!
Old 06-08-2006, 01:38 PM   #7
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
Sounds like a good idea. If I had the time to do this I would also. It is going to be tuff to just get my vf34 and supporting equiment on in time.
John__Gotti is offline   Reply With Quote
Old 06-25-2006, 09:17 PM   #8
02WHITEDUB
Member#: 96793
02 ProTuned TD04
So, today I tackled Stage One of my little P&P project!
A friend let me use his air tools at his shop, and in 3 hours I was done!
The IC inlet elbows were first. I started by using a carbide burr for about 20 seconds but didn't like how rough it was grinding. I switched to a flapper wheel (about 180 grit) and did the rest of both elbows with only the flapper.
I only went in about 1.75" but I went a little deeper on the casting marks.
It was EASY and only took about an hour of grinding/sanding to get results like in the borrowed picture below.
Next, the throttlebody. Easy to remove with the IC already off, it took an extra 10 minutes to remove for a n00b.
I did the TB the same: Flapper wheel only, basically going around and around the inside while rotating the piece and standing in different spots to eliminate any deep/shallow grinds. I went about 1" deep with a smooth taper.
While I was in there I noticed how much the bottoms of the screws in the butterfly protrude (4 threads or so) so I carefully hand-filed them down to about 1 thread sticking out.
My results were similar to the borrowed pics below, except with a less polished finish.
^^Nasty edge there^^
^^That's better!^^
My impression so far is that my car felt really strong, with smooth throttle response, for such a hot day. That's probably just wishful thinking, but it couldn't have hurt.
Next up: Headers
Anyone know of a CHEAP way to do a thermal coating on these babies? Anything at PartSource or JB's etc?
Old 07-06-2006, 06:29 PM   #9
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
good work. I'd like to do a P&P on my TD04 and tune it with my street tuner. Anyone have a guide on how to P&P a turbo?
06rexwagon is offline   Reply With Quote
Old 07-06-2006, 06:55 PM   #10
Flexx999
Member#: 36302
2006 Big 16G WRX
Addicted to Blue
A cheap away for thermal coating your headers would have to be the heat wrap. I did my down pipe and it isnt expensive at all.
Flexx999 is offline   Reply With Quote
Old 07-06-2006, 07:49 PM   #11
Rat Fink
Member#: 111609
2006 WRX Sedan
Rally Blue
They say heat wrap traps in moisture and promotes corrosion though.....I've heard stories of headers not even lasting a year after they've been wrapped.
Theres a company called Jet Hot....they're a little pricey because you'd have to send your parts to them to be coated......but from what I hear their ceramic coatings come back super shiny, and don't discolor, bubble, or peel.
There's a place in Calgary called top gun coatings.
A company in Red Deer called Metalstrip and Coatings Inc.
and a company in Edmonton called Perfection.
Not sure how the local guys are....but I hear they're cheaper.
Rat Fink is offline   Reply With Quote
Old 07-06-2006, 08:31 PM   #12
mac_82
Member#: 92468
I had the header for my civic done at top gun, they did a really good job on it.
mac_82 is offline   Reply With Quote
Old 07-12-2006, 02:55 AM   #13
02WHITEDUB
Member#: 96793
02 ProTuned TD04
I called Perfection the other day and was quoted about $220 for a ceramic coating of headers and crosspipe. This was over the phone though...I'm sure I could get a better price going down there as they probably do big V8 headers. I also had Marty at ProMax Performance (usually muscle car/truck stuff) quote me about $140 for the same service. Does this sound about right? I'd FAR prefer ceramic to heat wrap.
I was also lucky enough to 'borrow' a set of headers to do in my spare time! I'll take some pics of the progress!
I need to get these P&P'd headers installed - along with a turbo inlet and sparkplugs before the ProTune! I'm gonna be busy...
Maybe I'll finally hook up that IC sprayer...*sigh*
And re-wire my power block...
And fix my clock...
And replace that headlight bulb that's a bitch to get at...
Old 07-12-2006, 09:37 PM   #14
Rat Fink
Member#: 111609
2006 WRX Sedan
Rally Blue
I'm totally new to 4 cylinders. sounds like that quote isn't too far out to lunch. I've heard of V8 headers costing 250ish.
Old 07-21-2006, 06:53 PM   #15
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Whew! All done!
I worked on my car from 7:00pm until 4:30am and got everything installed, and leak-free! That left me 4 hours until my ProTune slot - plenty of time to spare!
Can't really say what gains the headers might have given because I also swapped plugs, fuel/air/oil filters at the same time, but the car felt great on the drive out to the dyno.
I ended up putting down 235wtq and 229whp on a conservative, safe tune on 91 kerosene. We need to get some basic stage 2 WRX results in so I can see if all of this P&P action made a measurable difference - though my butt dyno is a finely-calibrated instrument and it says 'Yes.'
Sorry, no pics of the header portions, but I will say that I learned that having a floor creeper is invaluable. I did my UP/DP without one and my back was raw for days. I also found a die grinder with a skinny 6" shaft so I got all the way into them except for a 2" portion on the passenger-side header.
Anyways, don't just sit there, DO IT! It's easy, and I'll be happy to sell/lend my skinny die-grinder to any aspiring P&P artistes. It was REALLY hard to find. House of Tools didn't even think they existed...
For Sale or Trade (PA): Blitz SUS intake Ported & Polished a little PA04STI Engine/Power/Exhaust 4 05-20-2007 03:12 AM
For Sale or Trade (PA): Blitz SUS intake Ported & Polished a little PA04STI MAIC Private Classifieds 0 04-24-2007 03:25 PM
pics requested for port & polish heads. lazzy8oy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-14-2006 04:24 AM
Stock Intercooler Elbows - Ready for port & polish! drees Private 'For Sale' Classifieds 1 05-31-2005 11:57 AM
Ported & Polished TD04 Turbo for sale djdorazio Private 'For Sale' Classifieds 5 01-20-2004 06:13 PM
