Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-05-2006, 01:32 AM   #1
traction issuez
Member#: 86559
2005 RS Wagon
Default type of sensor the hydra uses for wideband
i know the hydra uses NTK L2H2 UEGO, does anyone know a gauge "afr" will tap into this type of sensor so i can see the AFR at all times without the need of a laptop? if not i'm just going get the plx m-300 or innovative gauge setup. the only reason i ask this is because i don't want to weld another bung to the downpipe, but if i have to then i will.
btw, does hydra cancel the rear o2 out and uses only the bung on the manifold?? i don't remember much things because i havn't touch my sti in ages since it's 400 miles away. if it cancels out i can use that secondary o2 as another wideband right?
sorry for so much questions.
-mike
traction issuez is offline   Reply With Quote
Old 06-05-2006, 05:56 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Mike,
The Hydra does not use the front 02 sensor but can use the rear 02 sensor but isn't required to do so. MOTEC and a few other systems use the NTK sensor.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Anyone else Using the Hydra EMS for N/A Whiteghost 2.5 Normally Aspirated Powertrain 5 08-06-2007 09:31 PM
What is the best type of oil grade to use for motor with Forged pistons? zigger Service & Maintenance 3 02-01-2006 01:54 PM
o2 sensor used for wideband vs. reg o2 Stiguy247 Engine Management & Tuning 1 06-15-2005 02:22 PM
What type of sensor is the stock WRX O2 sensor? Patrick Olsen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-06-2002 05:17 PM
What type of inline fuse to use for Sony MP3 deck and wacky wiring? remarcable Car Audio, Video & Security 4 08-23-2001 10:21 PM
