Old 06-05-2006, 12:09 PM   #1
Mr. Sadface
Guest
Member#:
Question EcuTek Question
I’m planning on switching from my Spearco top mount intercooler, to an Arc front mount intercooler. This is the only change that will be made. I was curious to know if this type of switch would require a new reflash.
Old 06-07-2006, 03:52 PM   #2
BrentS
Member#: 96601
2004 WRX
When I went for the stock TMIC to a TXS huge TMIC, my ECUtek guy said that this was not enough to warrant another re-flash, and the ecu would learn the more air flow.
BrentS is offline   Reply With Quote
Old 06-07-2006, 06:16 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you expect to be making higher peak torque at any particular RPM then you could be using timing and fueling values that weren't able to be tested when you got your original tune.
Jon [in CT] is offline   Reply With Quote
Old 06-08-2006, 12:43 PM   #4
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
I agree with your statement, but my guess is TEH JDM is asking if he needs to get retuned because it might cause more harm than good.
Installing a front mount from a tuned top mount intercooler, usually results in lower boost levels. This in turn can affect timing/fueling negatively or positively depending HEAVILY on how the tuner programmed the ECU.
I would ask your tuner if this will be ok, he/she would know best if this will work fine or will need to be reprogrammed.
If you have any more questions, ask away,
Cheers,
William T. Knose Jr.
Lead Programmer
Crawford Performance / I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
ecutek question onesillyracer2k2 Engine Management & Tuning 1 08-11-2003 03:08 PM
ECUTEK Question? AntiochCali Factory 2.0L Turbo Powertrain 4 06-30-2003 11:31 AM
A few tough ECUTEK questions.... Red Rocket Engine Management & Tuning 5 01-18-2003 11:15 AM
ECUTEK Questions for Shiv NotoriousWRX Factory 2.0L Turbo Powertrain 77 12-12-2002 08:29 AM
Another ECUTEK question... thebusiness999 Factory 2.0L Turbo Powertrain 1 12-01-2002 03:55 PM
Message Board Statistics All times are GMT -4. The time now is 04:04 PM.
