Old 06-05-2006, 04:22 PM   #1
blueturbo2
Member#: 21881
2005 Forester XT
Default Problem with ecuFlash on 06 STI
I have install ecuflash 1.27, have the openport 1.2 cable, and it is reading it as com4 which is selected on ecuflash.
I try to read the rom from the car with the ignition on selecting 05-06 Subaru DBW STI/WRX/Legacy and it gets an error vaidating the kernal
Anyone know what is going wrong?
blueturbo2 is offline   Reply With Quote
Old 06-05-2006, 04:24 PM   #2
Freon
Member#: 88322
2009 BMW 135i
You're probably doing it wrong. Did you connect the green test connector? Did you turn your ignition on JUST before you hit the "ok" on the read rom confirmation dialog box in Ecuflash?
It does sound like your COM port is selected correctly.
Freon is offline   Reply With Quote
Old 06-05-2006, 05:25 PM   #3
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
Has the car been reflashed at all?
colby is offline   Reply With Quote
Old 06-05-2006, 05:43 PM   #4
blueturbo2
Member#: 21881
2005 Forester XT
Got it...the green test connector was not fully clicked together
Old 06-05-2006, 06:50 PM   #5
blueturbo2
Member#: 21881
2005 Forester XT
I have a second problem now.
It seems to read fine and finishes, however under parameters, there are only two ignition maps (A and B which are exactly the same) and nothing else. Is this an issue with it being an 06 or am I just doing something wrong here
Also, the ecu is stock, no reflash of any kind
Old 06-05-2006, 11:30 PM   #6
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Can you go to openecu.org and post there w/ the rom.
Thanks
west_minist is offline   Reply With Quote
Old 06-06-2006, 03:25 PM   #7
blueturbo2
Member#: 21881
2005 Forester XT
Done. Its in the reflashing software section
Problem with DP on 05 sti mark.j86 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-10-2008 10:46 AM
Problem with EcuFlash & Enginuity reading maps differently! akira02rex Open Source Reflashes 3 03-19-2008 03:04 PM
Boost drop problem with 20G on 05 STi Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 71 08-17-2007 11:25 PM
Problem with GT Spec Strut Tower bar on 06 STi Marcus K Brakes, Steering & Suspension 11 10-28-2006 09:49 AM
..problems with COBB on 2004 STi WipeOutXXL Engine Management & Tuning 3 10-22-2005 03:22 PM
