Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-05-2006, 03:42 PM   #1
x99percent
Member#: 27108
2004 STi
2004 A4
Default Hydra: What are you using to measure your boost level?
Since day one, I've noticed a discrepancy between the Hydra's boost reading and my three other boost-reading devices (gauge, EBC, and turbo timer). For example, during a pull, my boost level will hold at ~22psi as indicated by my other gauges, but the Hydra logs will only show ~19psi.
My real question is this: When people are tuning a Hydra-equipped car to "22psi", are they reading that "22psi" from a gauge or from the Hydra logs?
x99percent is offline   Reply With Quote
Old 06-05-2006, 04:06 PM   #2
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I've heard Phil mention before that the Hydra reads low.
Mine, for whatever reason, seems to pretty accurately represent what I see on my mechanical Omori boost gauge. It's tapped off the vac line at the front of the intake manifold behind and to the right of the PS pump.
jblaine is offline   Reply With Quote
Old 06-05-2006, 05:19 PM   #3
Element Tuning
Member#: 54918
Correct. The Hydra reads in "absolute" and will differ in readings taken from devices that read in "gauge" mode. It's typical to see about a 2 psi difference. My E-Boost reads very close to my Hydra but my Defi gauge is 2 psi higher. Changing the MAP sensitivity in the Hydra will also have an impact but setting it too sensitive will result in larger variations of the readings due to valve opening. You want to make sure it’s a stable read as it impacts what load cells are utilized.
Thanks,
Phil
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-09-2008, 10:24 AM   #4
vids
Member#: 120113
2002 WRX, full-race,
GT35, built engine, etc.
I also have about the same question. I actually have 3psi higher reading on my boost-gauge than in my GEMS ecu. The thing I wonder about is which one should I trust when mapping? The gems value is on the safe side of boost-pressure, but the gauge-value is a bit more brave.
I like to get the most out of the engine but still live a little space for errors and hot days. Those 3 psi actually represents some of that space that I may or may not have
vids is offline   Reply With Quote
Old 06-09-2008, 09:05 PM   #5
bannerd
Member#: 110771
2006 WRX
black
I did a T from the intake manifold to my guage sensor. I think that is the most accurate results you will get. The AP also has a boost reader which is pretty accurate. I'm running DEFI guages which is crazy setup as it logs the highest recordings.
bannerd is offline   Reply With Quote
Old 06-09-2008, 11:39 PM   #6
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I find the Hydra boost reading is similar to a AEM or other true MAP sensor absolute boost reading. I would rely on the Hydra over the typical boost gauge.
Many boost gauges read on the high side or at least that is what I have observed.
Try to look at your Hydra with the car off and compare to your barometric readings from NOAA.
Dyno Flash is offline   Reply With Quote
Old 06-10-2008, 08:07 AM   #7
vids
Member#: 120113
Thanks! The barometric readings seem ok, so I guess I should trust the absolute map-boost readings. I have a 3 bar map-sensor, so I guess it would be quite accurate up til 2 bars or something like that?
What are you using to treat your leather? JiveMasterT Interior & Exterior Modification 1 09-03-2006 11:14 PM
What do you use to fit your fit, sills etc to the scoob.. Rice Devil Interior & Exterior Modification 0 07-12-2006 10:29 AM
What are you using to replace OEM tires? lark6 Forester Forum 7 07-31-2001 04:11 PM
('93-'01) What do you use to wash your car? Mike Smith Impreza Forum 19 05-06-2001 08:33 PM
rallispec intake owners: what do you use to clean your pipercross filter? M a t t General Forum Archive 3 03-07-2001 09:07 PM
Message Board Statistics All times are GMT -4. The time now is 06:33 PM.
