Old 06-05-2006, 10:28 PM   #1
bdon22
Member#: 113940
2006 WRX
Steel Grey Metallic
Default Rear Differential Cover
Is the optional Rear Differential Cover necessary?
bdon22 is offline   Reply With Quote
Old 06-05-2006, 11:06 PM   #2
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
What do you mean by an optional Rear Differential Cover? Do you mean a skid plate? A skid plate is only necessary if you spend a lot of time off road jumping over rocks etc...
STirocket is offline   Reply With Quote
Old 06-05-2006, 11:58 PM   #3
kreitz3
Member#: 100242
I have one and broke one of the nuts that's welded onto the top of the rear subframe when i put my tranny back in. I need get under there and take that bolt and nut out of there because it makes my car sound white trash when I start from a stop.
kreitz3 is offline   Reply With Quote
Old 06-06-2006, 12:02 AM   #4
SigmaRacing
Member#: 114735
2006 WRX
It all depends on what kind of driving you do. For street driving or even Solo I or Solo II its not necessary as you're unlikely to strike the rear diff with anything on the track or road. Where it comes in handy is if you drive a lot of gravel or logging roads. Its way easier to replace a $100 piece of steel than the whole rear diff, and if you look under the car, its kind of exposed if you're driving rutted gravel roads...
SigmaRacing is offline   Reply With Quote
Old 06-06-2006, 12:57 AM   #5
bdon22
Member#: 113940
2006 WRX
Steel Grey Metallic
That totally answered it for me.. thanks
Old 06-06-2006, 09:01 AM   #6
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
The rear diff is a jacking point. You can drop the car onto the diff without any ill effects. If you plan to run down rocky roads at high speeds, yeah, a rear diff protector might help.
Calamity Jesus is online now   Reply With Quote
DIY Perrin Rear Differential Cover Installation PERRIN_Ken Transmission (AT/MT) & Driveline 75 02-02-2016 04:07 AM
perrin rear differential cover arrowscooby Drivetrain 2 04-05-2009 02:04 AM
Perrin Rear Differential Cover JSC Speed Drivetrain 2 12-22-2008 05:45 PM
Cracked rear differential cover! Silverstg2 Transmission (AT/MT) & Driveline 10 10-21-2008 12:36 PM
