#1 |
Member#: 7555
South East
I decided to replace my timing belt the other day after noticing some chewing going on with the top of the belt. One of the belt guides was just barely touching which was wearing that area. I also decided to replace the belt tentioner at the same time. However, I stripped a few threads and decided to get a longer bolt to compensate on the tentioner. Well apparently the bolt was not the correct grade because three days later the POS broke, leaving me stranded on the interstate. No more bolts from Home Depot
When that happened, I immediately pushed the clutch in when the engine lost power. I knew that losing power couldn't have been good CEL, dash lights and all. I looked under the hood and my greatest fear was confirmed. It was of course the tentioner that had let go and my poor belt was just hanging on to the pass side cams. As luck would have it, I repaired the threads with a helicoil and put everything back together over the weekend. The damned thing is in perfect running condition. I just did a compression check tonight and each cylinder is the same as before. Really odd! So I thought these were interference engines?? I've got zero damage. I was thinking that because my pistons have deep valve pockets that might be it, but on the other hand it's the Int valve to Exh valve contact is what's the problem.
#2 |
Member#: 22290
Vehicle:2002 WRB WRX Wagon |
Well, if you don't have any problems then you are super lucky. I always understood the timing belt coming off to mean the end of valves and pistons, but maybe not (or at least not in this case).
#3 | |
Member#: 7555
South East
Yeah, that's what I don't get. Was this my 'get out of jail free' card? I'd say the rpms were just over 3krpms while cruising along when it happened. I wonder if it's in the FSM or stated by Subaru that the valves will clash? |
#4 | |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
It was, for sure. They will interfere, I can attest to that. Good to hear you came out okay. I once dropped a valve in a SBC while idling through a drive-thru....as soon as I heard the "TING", I shut it down. Pulled the head, replaced the valve and keeper, pressure checked everything....car made a 9.00 pass that weekend. Pure luck.S. |
#5 | |
Member#: 7555
South East
That's what I'm thinking too. The whole thing cost me $30 flatbed towing (ins. paid $50), $56 Helicoil kit, and a $16 easyout + drillbit for the broken bolt. I didn't do a leak down test but the comp test was enough to convince me that it's good to go. I left the gauge pressurized for about 20 seconds for each cyl. There was no pressure loss at all. In the past, I've seen where a valve wasn't seating while performing a comp test. The gauge would shoot up and down with each revolution of the crank. So I trust the results ![]() |
#6 |
Member#: 69343
South East
Vehicle:2000 nothing good slow |
These motors are probably capable of making nasty internal contact, but I'm just thinking out loud here... When the timing belt completely releases, the cams will pop to a resting point and stop. Even if they catch between the close side of the lobes I think the valves are going to be closed or very very close to it. Could be wrong there.
Jumping timing on the other hand, could cause contact, but the car would run like poop and hopefully give the driver a hint that he needs stop the car soon, before damage occurs. |
#7 | |
Member#: 81633
Vehicle:'98 RS-T Blue |
#8 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
9 second, and its a sbc...which i assume equates to "small block chev" which means a lot more displacement than an ej series motor
#9 | |
Member#: 18960
South East
It WAS a 5.61 1/8 mile car with a 540 CID BBC, for the record, but ran in the low nines on a 434 CID SBC, all motor....I retired and sold the car recently....but I'm sure the owner will hook you up with a race if YOU have something to brag about. Not everyone is a blowhard, pal. P.S. Bring a Hayabusa on spray, or stay home. S. |
#10 |
Member#: 69343
South East
Lookin' for proof on the internet
I'd drive down from Breckenridge and find out. IF n2 is lying by five or more seconds you might have a chance That's why I get so pissed about dropping this much time and money into an import. Just to build a, god-help-me, reliable mid 12s car. Woopdee-friggin'doooo! I miss V8s. I don't miss the fuel consumption though. And if dropping a valve counts as "interference" I did almost the same in a 429 ford motor once... but it was a bolt that was inadvertently dropped into an intake runner. The truck made it all the way from Greensboro NC. to Annapolis Md. drove around for a week and all the way back to Greensboro (but not quite all the way home ) before the bolt made its way through the intake valve and started mauling the piston. Let's just say I did NOT stop in time to fix that problem. |
#11 | |
Member#: 18960
South East
I am lying. Busted. Dude is living under a rock. 8 second street cars are not that rare down here, in MD/DC/VA, or the Houston area. Been drubbed by a few in both places...one was a Chevelle wagon. Sorry. Back on topic.<Knock-knock> for dropped valves talk. S. |
#12 | |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
You got lucky the belt came off the way it did as quickly as it did. Home Depot bolts for timing assembly. Sweet ![]() I stripped the threads for one of the idler pulleys when I did my SB swap. ![]() Heli-coil kit + threadlocker has held it for 7000 hard miles now. Glad to hear everything came out okay, Todd. |
#13 |
Member#: 7555
South East
Yep guys. I think 2phless has the right idea. They probably were close enough to being closed when the belt came free. I think out of the 4 cams, only the driverside intake had tention on it, as in the valves were in the open position. The other 3 seemed to be at the bottom of the lobes for the most part.
Jeff, imagine if aluminum blocks came with SS inserts from the factory. I was told by a buddy of mine that a lot of the aluminum parts on military planes have this, or at least they were like that when he was in the Navy. The Helicoils are SUPER strong. I don't think it'll be a problem again. And yeah, the HD bolts are a NO-NO I won't be doing that anymore. In my defense though, it was late on a Sunday afternoon and nobody else was open. Of course I should've been more patient and fixed it with a thread insert to begin with and not the longer bolt. |
#14 |
Member#: 8512
South East
SS inserts would be excellent. Cost cutting is a bitch
![]() I wrote "Righty tighty, lefty loosey" 1000 times as penance. |
#15 | |
Member#: 81633
#16 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Tmarcel,
Were you aware that you can replace the tensioner bracket that bolts to the block? Here's the part number. 13156aa062 It's about 25$ |
#17 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
#18 |
Member#: 8512
South East
No, YOU shut up!
#19 |
Member#: 32792
NESIC
no YOU shut up!
todd, what grade was the pos bolt? |
#20 | ||
Member#: 18960
South East
Two friends fussing over my hijack. I'm hurt by my actions. Really. No, I am not kidding S. |
#21 | |
Member#: 7555
South East
I forgot that it was a separate part until I began trying to repair it on the car. I took it off and then repaired it. Buying a new one could have saved me money and a headache Oh well, at least I know for future ref. |
#22 | |
Member#: 7555
South East
Wish I knew. Is POS a recognized grade Lesson learned ![]() |
#23 | |
Member#: 81633
In an earlier posts you are saying that cars in the low 9’s (potentially 8’s) drive on the street. The link below is a high 8 second car and I’d be willing to bet the only street time this car sees is on a trailer. I am not saying that I can go faster, I am just calling ride5000’s bluff. Street car ![]() |
#24 |
Member#: 32792
NESIC
are you talking to me?
![]() all this, and i didn't even know i had a bluff to call... |
#25 | |
Member#: 18960
South East
2mile, if you've never seen a mid 8 or low 9 street driven car, you have been living a sheltered life. I've built 3 for me personally. Do I make 100 mile trips with them? No. 93 octane? Hardly. Do they have A/C or cruise? No. They are a single-purpose automobile, designed to crack the ass of young punks like yourself that think 8-9 second cars aren't on the street. P.S. You're not calling anyone's bluff by asking for a time slip... Anyone can whip one up in Photoshop. I don't have anything to prove to you, or anyone else....but if you're THAT naive, call (256) 538-7223, and ask Jason Collins (the track owner) about Steve Jordan's Black 88 coupe Mustang (now sold) with the Chevrolet drivetrain. Jeez.S. Last edited by n2xlr8n; 06-14-2006 at 10:04 AM. |
| Thread Tools | |
| Display Modes | |
| Timing belt tentioner for EJ20x/25x are they all the same. | bugeyes | Built Motor Discussion | 2 | 01-27-2008 11:02 AM |
| Timing belt tentioner? | Dan17z | Factory 2.0L Turbo Powertrain | 4 | 12-27-2006 02:40 AM |
| Please help: Stripped bolt on timing belt tentioner. | awd4ever | Normally Aspirated Powertrain | 10 | 10-29-2003 01:28 PM |
| Please help: Stripped bolt on timing belt tentioner.(cp) | awd4ever | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 10-23-2003 12:57 AM |
| Timing Belt 2 teeth off.... | dug-e-fresh | Factory 2.0L Turbo Powertrain | 13 | 09-07-2001 02:04 PM |
