Old 10-13-2001, 05:27 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Arrow question about FMICs
Just curious as to why people are deciding to go to a FMIC? What research did you do to come to your conclusion? Can someone post dyno-graphs or something of a car that had a TMIC and went to a FMIC?
In a perfect world, you would have an IC that is the size of a FMIC mounted where we put the TMIC. You ALWAYS want your IC as close to the throttle body as possible. With a FMIC, there is so much piping on our cars that it seems that it would cause pretty bad throttle response (under boost and vaccum) and a lot of pressure loss for a while.
So, please convince me that the FMIC is the way to go. I might do this if I you can do this, but you have your work cut out thanks
Eric
Eric SS is offline   Reply With Quote
Old 10-13-2001, 05:36 PM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
The FMICs have much higher air flow due to their position and do not suffer from the heat soak problems of the TMIC. The trade-off is that all that piping for the FMIC has a negative impact on throttle response and exposes the piping to a lot more heat as it crawls all around the engine. I plan to stick with a TMIC.
Ben
bsquare is offline   Reply With Quote
Old 10-13-2001, 05:46 PM   #3
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
what happens if its raining and water splashes on your FMIC?
Penguinking is offline   Reply With Quote
Old 10-13-2001, 05:51 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Even better. it will help discipate heat
Eric
Old 10-13-2001, 06:14 PM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
What an odd question. An intercooler operates very much like the radiator in your car, but rather than cooling liquid it is cooling air. Why would water splashing it do any harm? Many rally cars actually have water jets spraying their intercoolers to lower the temperature.
Ben
Old 10-13-2001, 06:36 PM   #6
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
well yeah....im a newbie...hehe, i dunno that much about IC
Old 10-13-2001, 06:37 PM   #7
Andrew
Member#: 1170
2005 STi
ben i think Penguinking is just a little confused on how an IC works
penguinking, an IC cools the air that is brought in from the turbo and intake. it doesnt bring in anymore air than what is already there. i think you are confusing it with an intake, which you dont wnat the outside elements clogging.
Andrew is offline   Reply With Quote
Old 10-14-2001, 02:20 AM   #8
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
A front mount does not let the heat from the motor warm it up. Sure as we are going down the freeway it's no big deal to have a top mount since there's lots of air flow. The front mounts though are almost always going to be a little cooler and therefore better for overall performance. The downside is all the plumbing.
On another note, if you check all the 10 second Imprezas at www.autospeed.com, you'll see that they all have front mount intercoolers... well that and a 2.4L stroker motor.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-14-2001, 06:32 PM   #9
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
This is a confusing subject, but I'll take a stab at it.
When picking an intercooler you must examine what the motor is going to be used for. Here are a couple of examples.
If drag racing is the soul perpose of the motor, instant throttle response isn't your main goal. What you want is the coolest intake charge possible. Heatsoak is also a major concern as the car will be sitting most of the time. Given this information, a front mount intercooler is best.
In my case I am looking for instant throttle response, while keeping a very cool intake charge. This is because I use my car for track racing, and hardly ever drag race. A top mount intercooler seves my perpose perfectly. Manifold Intake Temperatures are very low, and heatsoak isn't a problem.
Basically, examine what is most important to you and then examine how deep your pockets are
Cheers,
MattC
MattC is offline   Reply With Quote
Old 10-14-2001, 08:37 PM   #10
Andrew
Member#: 1170
2005 STi
Cool
take one of those small freezers for aparments and dorms. rip it apart and take the cooling system out of it. hook it up to your alternator. stikc it right near the throtlle body and there you go. nice and cold intake charge and can keep a soda or beer cold.
Old 10-14-2001, 09:25 PM   #11
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
i wanna see someones car with that system hooked up!
noob question about fmic meatball18 Subaru Conversions 3 10-23-2005 10:44 PM
Question about FMIC bhs515 General Community 9 09-21-2005 11:26 AM
yes another stupid question about FMIC Perrin vs APS vs turboXS modaddict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 09-12-2005 08:36 PM
Question about FMIC. Please help! ChinkyWRX Engine Management & Tuning 3 04-24-2003 12:44 PM
Question about FMIC WRteXmeX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-21-2002 04:24 PM
