Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-13-2015, 09:30 PM   #1
Rizen
Member#: 157002
2011 STI
Default TD06 with non-stock coolant line fittings
Hi there, so I'm installing a TD06-20G right now and whoever built this turbo didn't use the normal coolant line routing holes on the center section of the turbo. It's hard to describe so
Normal 20G center section
Blocked off | | coolant in
Blocked off | | coolant out
My 20G
Coolant out | | coolant in
Blocked off | | Blocked off
Basically instead of having both on one side, inlet on the top and outlet on the bottom, the ports are both on the top on opposite sizes.
This seems actually easier to route but I'm wondering what negatives there might be in terms of cooling efficiency and if I should worry?
Sent from my iPhone using NASIOC
Rizen is offline   Reply With Quote
Old 02-13-2015, 10:34 PM   #2
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Don't think it will impede flow.. since there is a "in" and out" I do wonder what path it goes tho.. IMO... should be ok..
Scooby South is offline   Reply With Quote
