View Poll Results: How often do you clean your MAF sensor?
Once a month or more 23 3.50%
When i change my oil 91 13.85%
When it needs it, I can tell by my EM or my butt dyno 159 24.20%
NevAR 387 58.90%
Multiple Choice Poll. Voters: 657. You may not vote on this poll
Old 02-08-2010, 05:13 AM   #101
TheNailman
Member#: 133676
2005 WRX
cool thread. will try this when the temp breaches the freezing mark.
TheNailman is offline   Reply With Quote
Old 02-08-2010, 05:14 AM   #102
bryantkalagian
Member#: 226391
01 Silverado
Originally Posted by hvymetal86 View Post
The hollow of the MAF is the open inside of the tube going up from the bottom (farthest into the intake when it's installed) to the top with the plug. The heater wires are very hard to see, but they're up inside the hollow tube. When it says indirectly spray it means not straight up into the tube, but angled so the spray hits the walls of the tube before it hits the heater wires.
what should i use to clean it?
bryantkalagian is offline   Reply With Quote
Old 02-08-2010, 05:20 AM   #103
bibs
Member#: 199879
2009 Forester
FXT
found a bottle of this at thome, do i need MAF specific cleaner or will this work ?
http://www.lpslabs.com/product_pg/cl...g/CFCFree.html
bibs is offline   Reply With Quote
Old 02-08-2010, 09:49 AM   #104
TheNailman
Member#: 133676
2005 WRX
just did mine, and then did some errands around town.
it DOES seem to run a little smoother. .. .not a giant difference though.
Old 02-09-2010, 07:25 PM   #105
AspenSti06
Member#: 209616
2006 STi
"Frosty"
by any chance does anyone know the part number for stock maf screws for a 06 sti?
EDIT: Part Number is 904510056
AspenSti06 is offline   Reply With Quote
Old 03-09-2010, 10:35 PM   #106
jays05
Member#: 78165
05 STI 35r + e85
Wow, the other day my car started stalling out and while cruising, AFRs were jumping between 16 and 11. I also got a P0030 CEL for the front o2. I was right about to replace the front o2 when I decided to log the MAF... sure enough the MAF volts were jumping around when AFRs did. I took the MAF out, cleaned it, and all the symptoms + CEL disappeared!
jays05 is offline   Reply With Quote
Old 03-10-2010, 11:23 AM   #107
inCLINEd
Member#: 204785
06 sti
obp
I did some logging mpg before and after cleaning the maf. Before I was averaging 16.3mpg with a peak (highway driving) of 22mpg. After the cleaning and a little time to let the ecu relearn, im averaging 19.7mpg and peak at 23.9mpg on crappy winter blend. Defn worth the 3 minutes it takes to do. :thumbup:
inCLINEd is offline   Reply With Quote
Old 03-10-2010, 04:44 PM   #108
BENSREX
Member#: 39718
2007 WRX
I've never used any type of "cleaner." I've always just used a clean q-tip and rubbed the MAF gently, then reinstalled.
Does this do the trick? Or am I doing it all wrong?
BENSREX is offline   Reply With Quote
Old 05-05-2010, 10:10 AM   #109
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
i don't think the MAF on my 06 has ever been cleaned. finally figured it cant hurt so stopped at advanced auto parts on my way home and picked up a can of CRC's MAF cleaner. cleaned the MAF and reset the ECU and performed the vishnu ecu reset this morning on my way to work.
maybe im crazy but i noticed the engine seemed to act a lot smoother and a lot of the low gear, low speed bounciness (1st gear @ 5mph as en example) was gone or greatly diminished. figure cleaning this is good prep work as i prepare to go stage 2 later this summer. and thanks nhluhr for the easy instruction on how to clean the MAF with least risk of damaging it .
roccer is offline   Reply With Quote
Old 05-05-2010, 10:15 AM   #110
Ryan314
Member#: 82989
Hybrid VF22
Once a year every spring.
Ryan314 is offline   Reply With Quote
Old 05-06-2010, 10:12 AM   #111
BENSREX
Member#: 39718
2007 WRX
I thought the decreased power/rough idling was my MAF so I cleaned it. Nothing happened.
Then I remembered that I haven't cleaned my K&N air filter for 25-30,000 miles... the car is back to normal after the air filter clean! Woo. Just thought I'd share for anyone else that hasn't cleaned/changed the air filter in a while.
Old 05-06-2010, 01:28 PM   #112
Bakerbrdz
Member#: 132394
1.21 gigawatts?
Lighting bolt power bitch
this thread is stupid!!!
Bakerbrdz is offline   Reply With Quote
Old 06-03-2010, 09:12 PM   #113
RdRx02
Member#: 248294
02 WRX 4DR
Sedona Red
Thanks for the pics and answers to the how to's on this topic. I've gotta try this as mine has probably never been cleaned. Hopefully something good comes of it and if it does I will post the difference.
RdRx02 is offline   Reply With Quote
Old 07-08-2010, 06:12 PM   #114
blackwrx07
Member#: 250632
2007 Impreza WRX
I went right outside and looked at mine, guess what? 33k miles and it was pretty fouled. Cleaned up in a jiffy, now that I have a K&N filter I'll do it regularly. Good thread.
blackwrx07 is offline   Reply With Quote
Old 07-08-2010, 09:16 PM   #115
Skullyg
Member#: 183919
2004 IMPREZA WRX STI
^ whats wrong with this thread..??? I think this is a great sticky for people to know that the MAF should be a yearly or more for scheduled maintenance. A lot of people (like me) wouldnít be educated about parts like this if it wasnít for the people who start threads like this.
On another note I was pissed I didnít see this thread earlier because I had a a/f problem thinking it was my fuel pump control unit, but I traced it back through the ECU to one of the sensors that flag the ECU. Checked my MAF and it was covered completely in carbon. Maybe thatís the reason my first motor blew up. This should be a lesson to people that one sensor not being properly monitored after mods can cause harm to engines. BEWARE!! lol
Skullyg is offline   Reply With Quote
Old 07-08-2010, 09:33 PM   #116
fastwrx25
Member#: 126441
03 bugeye
thanks for the bump, reminds me I should clean my maf.
the car hasn't been feeling smooth at idle and light throttle. I forgot to do this last time I changed oil.
fastwrx25 is offline   Reply With Quote
Old 08-13-2010, 05:46 PM   #117
jgardner9000
Member#: 219549
2009 STi
Bump.... Sorry this might seem like a stupid question, but how do I get the MAF unplugged from the wires? Do you just push down on that one clip? Mine won't budge
jgardner9000 is offline   Reply With Quote
Old 08-13-2010, 05:48 PM   #118
NJHK
Member#: 217248
2009 STI
push clip down and wiggle it out. Using a flathead screw driver helps.
NJHK is offline   Reply With Quote
Old 08-13-2010, 06:07 PM   #119
jgardner9000
Member#: 219549
2009 STi
Yea got it, screwdriver did the trick haha thanks
Old 08-13-2010, 06:18 PM   #120
NJHK
Member#: 217248
2009 STI
No problem. I had the same issue with mine...cleaned mine days ago and thats what I did.
Old 08-14-2010, 12:53 AM   #121
afg786
Member#: 251862
06 Stage 3 WRX
got mine 2 days ago, still havent driven it enough to feel it, but does feel a little smoother
afg786 is offline   Reply With Quote
Old 08-14-2010, 01:03 AM   #122
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
Thanks for the bump. I'm gonna clean mine tomorrow. It's been over 10k miles, so we'll see how it's doing.
PleiadesSTi is offline   Reply With Quote
Old 08-14-2010, 08:34 PM   #123
wariord
Member#: 246734
2004 sti
wrb
gonna do this today. good thread.
wariord is offline   Reply With Quote
Old 08-22-2010, 03:43 AM   #124
BLKonBLK05
Member#: 249379
2005 STI, black ....
hence the screen name
[QUO...TE=nhluhr;14049719]just fyi - if you do mess up that little o-ring, replacements are hard to find. i had to resort to using a completely different o-ring and "making it fit"[/quote]
If anything happeneds to that o ring it can get messed up...but I found the exact one at Lowe's ....supprisingly it works good as hell...2 for 55 cent..
BLKonBLK05 is offline   Reply With Quote
Old 01-03-2011, 11:53 PM   #125
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Ahem....120k miles. Never cleaned. But I'm REALLY PISSED that I paid $450 to YIMI SPORT in Santa Clarita for a "dyno-tune" and they did NOT check/clean this first!!! ARRGGHHHHH!!! (I told them the air filter was okay...OEM). I will call and ask them if a re-tune is the proper thing to do. (Yeah, they'll probably say nope!) They only got me +6 hp, but I think +10 ft.lbs. of torque on a stock set up.
Columbo is offline   Reply With Quote
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 09:30 PM
How often do you wash your hair (if you have any)? HoRo1 Off-Topic 33 12-02-2003 04:22 PM
How often do you clean your K&N/reusable air filter??? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2002 12:05 PM
how often do you wash your car? inpreza kid Canada Region Forum 12 02-24-2001 06:07 PM
How often do you clean your rims? John2.5RS General Forum Archive 12 05-22-2000 09:02 AM
