View Poll Results: How often do you clean your MAF sensor?
Once a month or more 23 3.50%
When i change my oil 91 13.85%
When it needs it, I can tell by my EM or my butt dyno 159 24.20%
NevAR 387 58.90%
Multiple Choice Poll. Voters: 657. You may not vote on this poll
Old 01-03-2011, 11:04 PM   #126
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
There is a pre-dyno checklist that you should always go through first. You should throw new plugs check gaps, new fuel filter, check for boost leaks, etc... to that list as well before going for a dyno tune
SBW is offline   Reply With Quote
Old 01-03-2011, 11:10 PM   #127
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Yes, new plugs, air filter, fuel filter...within 10k miles of dyno tune was good enough for me...and them. I didn't know about the MAF, BUT they certainly should have!!
The car runs fine, but I felt the boost was not as steady as it used to be prior to them tuning it. The reason I went in! It's better now. But I used to get 26 mpg average. That had dropped to 24 mpg. Then as expected after the dyno-tune, it dropped to 22 mpg with relatively gentle use of the turbo in all tests.
Columbo is offline   Reply With Quote
Old 01-15-2011, 04:14 PM   #128
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Default Did It, Do It!
I cleaned the MAF and IAT sensors and mileage went from 22 to 24.7.
Old 01-15-2011, 06:15 PM   #129
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Useful thread. Doing this soon. Thanks all.
SlimJim8804 is offline   Reply With Quote
Old 01-20-2011, 04:26 PM   #130
raddue
Member#: 254129
2006 STi
Thank you for posting this. I have an '06 STI which as far as I know has never been cleaned in the 52,000 miles on the odometer. I took mine out and it was pretty disgusting, let's see if this cleans up my rough idle problem...
raddue is offline   Reply With Quote
Old 01-21-2011, 11:13 PM   #131
wrx surfwagon
Member#: 262719
02 WRX
PSM with rust accents
i was thinking about doing this before i found this thread so when i saw it i got some cleaner and went for it. 177xxx on the odo, i doubt it has ever been cleaned. The car always stumbled a little bit at the onset of boost and i thought it was a transmission/suspension issue. Now pulls are clean, 100% different feeling. thanks the the OP on this one!!!
wrx surfwagon is offline   Reply With Quote
Old 01-23-2011, 04:50 AM   #132
mrlimit
Member#: 271316
2007 WRX TR
silver/gray
Default Definetly a good idea.
After I cleaned mine with a autozone brand maf cleaner and changed plugs the low RPM hesitation went away and gas mileage is just so much better. I was getting at most 23-24 now closer to 26 if I behave lol.
mrlimit is offline   Reply With Quote
Old 01-23-2011, 08:21 AM   #133
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yay no more maf sensor for me but yeah maybe every 2 months i did mine.
stretchedk7 is offline   Reply With Quote
Old 01-23-2011, 12:00 PM   #134
wrx surfwagon
Member#: 262719
02 WRX
so i reset my ecu the day after i cleaned my maf. The car pulls even better now, but the idle is really wandering on cold starts, sitting almost at 1800. when its warmed up and i start it seems to idle really low. The radio is frozen but i think i just have to unplug the battery again.. anyone experience this after the maf cleaning/ecu reset?
edit: just saw this was 2.5l so if anyone opposes this question i can start a thread in 2.0l
Old 01-25-2011, 03:12 AM   #135
wrx surfwagon
Member#: 262719
02 WRX
So turns out the wandering idle was due to the cold. All good.
Also, can anyone tell me exactly why cleaning the maf smooths out accelleration? I went from gettin a distinct stumble at 33-3500 rpm to a perfect, steady climb. is it possible the ecu was pulling timing? and is there anything i should check out to make sure nothing is damaged? I'm doing a comp test when i do my plugs in the near future
Old 03-24-2011, 06:20 PM   #136
SubieRSjustin
Member#: 262254
2000 00rs/99 legacy
silver/ tan
Would it be the same procedure for an 04 wrx engine? Replaced IAC and still have a weird idle.
Had a smoke test and there are no vacume leaks. Thanks
SubieRSjustin is offline   Reply With Quote
Old 03-25-2011, 08:18 AM   #137
Jetbob144
Member#: 248928
2006 STi
I have cleaned mine on the STI and done cleaning on several other peolpes high mileage cars, it has ALWAYS helped the way they run. always with a battery off reset of the ecu.....but great results on every vehicle I have done it to.
GOOD LUCK.
Jetbob144 is offline   Reply With Quote
Old 03-25-2011, 05:10 PM   #138
Bakerbrdz
Member#: 132394
1.21 gigawatts?
Lighting bolt power bitch
if you dont clean this every oil change or monthly, you shouldnt own this car and if you dont know how to clean it...........well you get the point!!
Bakerbrdz is offline   Reply With Quote
Old 03-25-2011, 05:26 PM   #139
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Please show me in the owners manual where it says to clean the MAF monthy or every oil change.
Bishop is offline   Reply With Quote
Old 03-25-2011, 05:30 PM   #140
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
...and that one tank only.
Still only averaging 21-22, 80% freeway @ 75-80 mph. Not bad I suppose. Doubt I'll ever see the 24-26 mpg I used to get.
Old 03-25-2011, 05:58 PM   #141
SubieRSjustin
Member#: 262254
2000 00rs/99 legacy
silver/ tan
Cleaned it with the crc maf cleaner. Took all of five minutes, seems to run a little smoother
Old 03-26-2011, 06:48 AM   #142
fastwrx25
Member#: 126441
03 bugeye
ah...which reminds me. time to do this again.
fastwrx25 is offline   Reply With Quote
Old 04-14-2011, 11:45 PM   #143
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
So let's say my car all of the sudden threw a lean code, and has been running kinda crappy since...what are the chances it's my dirty never cleaned in 76,000 miles MAF? Going to clean it tomorrow after work!
WRX_02_227 is offline   Reply With Quote
Old 04-15-2011, 07:10 PM   #144
NMccann99
Member#: 232769
I've had lots of vehicles with MAFs. Mostly american stuff, but I don't ever remember cleaning one, all draw through though. Blow through apps you need to watch things pretty closely as the PCV systems on Subarus pump a fair bit of crap back into the intake tract.
NMccann99 is offline   Reply With Quote
Old 04-21-2011, 11:50 PM   #145
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Well I cleaned my MAF and the difference is nothing short of AMAZING!!! It's like a brand new car.
Old 06-29-2011, 03:51 AM   #146
dtseng01
Member#: 105323
2005 Impreza WRX STi
Thank goodness I stumbled on this and the IACV thread. Most definitely doing both ASAP.
almost 60k and have never cleaned my MAF... and on top of that the last time I cleaned my K&N filter I over-zealously oiled it...
**facepalm with palmful of how-am-i-so-noob**
dtseng01 is offline   Reply With Quote
Old 06-29-2011, 06:18 AM   #147
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I have to change out the MAF in my Boxster every 15-30k miles and it doesn't like being cleaned. At $300 a pop, it gets kind of expensive. O2 sensors only last 60k and they are $300 each too x4. My STIs were cheap to maintain compared to this thing.
silver arrow is offline   Reply With Quote
Old 06-30-2011, 08:48 AM   #148
kungfuturkey
Member#: 286925
2006 Impreza WRX
I never thought of this.... I just bought my Subie and am doing some "new car" maintenance (06 WRX) also I was told that there is a filter before the turbo that you need to change and I can't find any information on this... Does anyone know of a secondary oil filter specifically for Subie turbo's? Sorry for the newb q's but my first Subaru (previously drove Infiniti)
kungfuturkey is offline   Reply With Quote
Old 06-30-2011, 12:38 PM   #149
simonella_virus
Member#: 183875
2007 WRX STi Stg2
i dunno how crappy your air filters are, or how dusty your environment is, but my 07's sensor was clean. 4+ years and clean.
simonella_virus is offline   Reply With Quote
Old 07-01-2011, 09:48 AM   #150
SBW
Member#: 38469
07 LGT spec-b
http://store.forcedperformance.net/m...Info_SubaruOil
read this
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 08:30 PM
How often do you wash your hair (if you have any)? HoRo1 Off-Topic 33 12-02-2003 03:22 PM
How often do you clean your K&N/reusable air filter??? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2002 11:05 AM
how often do you wash your car? inpreza kid Canada Region Forum 12 02-24-2001 05:07 PM
How often do you clean your rims? John2.5RS General Forum Archive 12 05-22-2000 08:02 AM
