Old 06-06-2006, 03:05 AM   #1
deluxsti
Member#: 84313
04 Aspen STi
Default not hitting boost with ap stage 2
i just bought a 04 sti with turboxs catted downpipe, hks catback, and ap stage two. but i am only spiking 15 lbs on the stage 2 map. what could be the reason im not getting 18+?
another question, would i gain anything by switching to a non catted downpipe?
deluxsti is offline   Reply With Quote
Old 06-06-2006, 06:23 AM   #2
k mier
Member#: 98000
05 sti [email protected]
Cobb stage 2 target is 17.2 psi. Hook up the AP and use it's live boost reading, maybe the guage is off? If it doesn't hit target, maybe something as simple as a leak before the turbo? There are several different maps on Cobb's website.
k mier is offline   Reply With Quote
Old 06-06-2006, 06:27 AM   #3
battousai
Member#: 44977
2015 Mustang GT
Maybe it hasn't had enough time to learn? I haven't used an AP in awhile since they came out so I dunno if anything has changed since then.
battousai is offline   Reply With Quote
Old 06-06-2006, 06:29 AM   #4
WR^2X
Member#: 37617
Switch to the HWG map.
WR^2X is offline   Reply With Quote
Old 06-06-2006, 02:36 PM   #5
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I'd call Cobb, they have good expierence with these issues.
There are a number of issues this can be. I'd reccomend checking the boost with the AP about 300 miles after the map has been installed, that should allow for sufficiant learning time. And give you an accurate boost reading to take to cobb.
parker/slc/gc8fan is offline   Reply With Quote
Old 06-06-2006, 02:43 PM   #6
deluxsti
Member#: 84313
04 Aspen STi
well, the AP has been on the car before i bought it, so i doubt it hasnt had enough time to learn it.
the car was also protuned and even on that map its only running 15 psi.
but the car was tuned at a higher elevation that where i am at. could that be the issue?
Old 06-06-2006, 03:24 PM   #7
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
It could be part of the issue, it being a custom map however, throws us supporting it out the window, the person who made themap would need to.
It's possible he set the boost at 15 psi.
Old 06-06-2006, 03:31 PM   #8
deluxsti
Member#: 84313
04 Aspen STi
i just got off the phone with cobb and talked to the guy that tuned the car, he said when the car left it was hitting 18 psi on the dyno. 4k miles ago, and he said it is most likely something mechanical.
what should i check to find the problem?
Old 06-06-2006, 03:59 PM   #9
ckanderson
Member#: 47445
2003 Charged Cobra
boost leak, intake restriction, exhaust restriction
ckanderson is offline   Reply With Quote
Old 06-06-2006, 07:12 PM   #10
deluxsti
Member#: 84313
04 Aspen STi
ok, i reset the ecu and its hitting the right boost now, but after i drive it for a while, it goes back down to 15 psi? could it be detonating and causing it to run less boost?
Old 06-06-2006, 07:33 PM   #11
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Doubtful.
I'd imagine somthing is bad in the boost control system.
Old 06-06-2006, 07:56 PM   #12
Christian.
Member#: 87604
If the ECU hears severe detonation then it will shut boost control off completely. If the ambleint temperature is high then the turbo cannot generate full boost because it is out of the effieincy range. The ECU does what it can to stay consistent and to save the motor from damage.
Take care,
Christian.
Christian. is offline   Reply With Quote
Old 06-07-2006, 03:47 PM   #13
deluxsti
Member#: 84313
04 Aspen STi
i figured it out. everytime i shut off the car, the ap goes back to the base map and not the realtime map, wtf?
Old 06-07-2006, 04:12 PM   #14
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
How can you tell?
Thats really wierd.
Old 06-07-2006, 04:14 PM   #15
supermarkus
Member#: 6971
2008 WRX STi
SSM
You do know that the AP only ever reports the base map right? You have no way of reading back that you are running a RT map.
supermarkus is offline   Reply With Quote
Old 06-07-2006, 04:14 PM   #16
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Even with the stg 2 base map, target boost is still the same. Many ppl just run the base map with no realtime map at all.
MF-DIF is offline   Reply With Quote
Old 06-07-2006, 04:18 PM   #17
deluxsti
Member#: 84313
04 Aspen STi
the base map is a protune map - 15psi
stage 2 or the protune realtime map - 18psi
im going to just make the base map stage 2 instead of the protune
Stg 2 not hitting boost and Ap help. StealthfishWRX AccessPort 12 08-10-2006 01:00 AM
Passed NY state inspection with AP stage 2 txl146 Tri-State Area Forum 15 08-25-2005 11:21 AM
dead car with AP stage 2 notyet227 Engine Management & Tuning 35 03-08-2005 10:27 PM
APS Red 65mm CAI with AP stage 2? Golfa Engine Management & Tuning 7 10-18-2004 10:18 AM
Strange boost levels with AP Stage 2 Schleppy Engine Management & Tuning 8 05-11-2004 03:19 AM
