Old 10-13-2001, 07:36 PM   #1
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Default EJ22T motor has no bottom bolt for the starter?? A little help please...
So I'm currently in the process of installing my EJ22T into the car. If all goes well I should be up and running late tonight or early tomorrow morning. While attaching all the chains to the motor, I had a slight panic thought which so far has proved out to be realistic.
The starter on a stock MY00 RS uses two bolts to secure itself to the block. Both bolts pass through the transmission bellhousing and then screw into the block. A complication arises when you install an EJ22T (4 bolt mating surface) with a MY00 transmission (6 bolt mating surface). The top bolt of the starter can still pass through the a hole in the bellhousing and screw into the block, however there is no hole on the block for the bottom bolt to screw into seeing as there is two less holes on the EJ22T verses the EJ25. As near as I can tell the only option I have is to drill out the hole in the starter to accept one size larger metric threads and tap out the hole in the transmission. I see no other way to secure the starter using both bolts.
What has everyone else done on this? And, if you have drilled/tapped it out, what size did you go with??
Thanks,
Fitz
Fitz is offline   Reply With Quote
Old 10-13-2001, 07:42 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Starters are jsut extra weight anyway... Just push start the thing
Eric
Seriously, I don't know, I'll go look at mine
Eric SS is offline   Reply With Quote
Old 10-13-2001, 07:54 PM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Early models had a stud on the tranny for the bottom of the starter mount. You can probably put a heli-coil and put in a stud like the earlier models. ( 10x1.25)
Ver.III is offline   Reply With Quote
Old 10-16-2001, 04:21 AM   #4
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Fitz you have PM...
HOK is offline   Reply With Quote
Old 10-17-2001, 12:41 AM   #5
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
You don't have to use heli-coil. Just drill and tap, like you said. If done properly it will hold very well.
LVSUBARU is offline   Reply With Quote
Old 10-17-2001, 11:29 PM   #6
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
I'm going to post my course of action in case anyone else ever does a search on this. I contacted my local dealership and was able to secure a stud free of charge. They had just scrapped out a transmission and pulled it off of there to give to me. The stock transmission bellhousing on a 4 bolt transmission has the hole tapped into the bellhousing. On the 6 bolt trannie's (99 SOHC and up) the hole in the bellhousing is actually larger than the stud. You're left with a couple of options.
1) Tap the stock bellhousing hole to X thread and use that diameter/thread stud. The starter will probably have to be drilled out as well to clearance the larger diamter stud.
2) Find a Heli-coil that has a 10x1.25mm ID (inner diamter) and a larger enough OD (outer diameter) so that you can tap that into the bellhousing. Use liberal amounts of loc-tite (careful: known carcinogen).
3) Machine out a special stud that has a larger diameter at one end and a smaller diamter (10x1.25mm). This way you can tap out the transmission but not have to drill out the starter hole.
I'll be exploring the second option but if I have to go with #3, I'll post this cad drawings.
Fitz
Old 10-18-2001, 12:27 AM   #7
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
#3 sounds like the best solution to me.
Megan Racing or what for the 05 STi? Little help... sigma69pi Brakes, Steering & Suspension 3 08-07-2007 10:56 AM
Bottom Bolt (not the nut) on rear strut stuck...need help bstoehr83 Brakes, Steering & Suspension 8 09-22-2006 05:37 PM
For those who have taken the LSAT ... Little help please Brady Off-Topic 34 12-23-2005 02:41 PM
IL: for the people with AP, HELP please ms3p Mid West Subaru Owners Club Forum -- MWSOC 5 10-22-2004 12:19 PM
How do I remove the bottom bolt on the strut? whiterabbit Brakes, Steering & Suspension 15 06-28-2002 08:45 PM
