Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 01-23-2001, 04:22 PM   #1
lucien2
Member#: 1519
1998 Volvo V70R
Question What's everyone using for brake fluid?
So I got powerstop pads on the way (I hope...the check to Primitive cleared last week!), but I also want to use better fluid. Paul sold me some Motul Dot 5 stuff, but a seasoned driving instructor I know says the stuff aint' worth it, especially if it is synthetic. He says I'd be better off with Blue dot, or something like that. Cheaper and more effective.
Soo..... what are you all using these days?
lucien2 is offline   Reply With Quote
Old 01-23-2001, 07:18 PM   #2
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post
I'm using SuperBlue.
Kevin
gtguy is offline   Reply With Quote
Old 01-23-2001, 09:33 PM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
Motul Racing 600 I've also used AP Racing DOT 5.1
GTBGUY is offline   Reply With Quote
Old 01-24-2001, 12:00 AM   #4
Ben
Member#: 423
2002 WRX wagon
Post
I'm using Motul 600 for my 92 Legacy turbo with EBC GreenStuff front pads and PBR rear pads!!
The car stops a lot better then before !!
Ben is offline   Reply With Quote
Old 01-24-2001, 12:08 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
If it is actually DOT 5 then do not use it in your street car!!!! DOT 5 is a synthetic silicone based fluid. It doesn't mix with "regular" fluids (DOT 3, 4, 5.1), it is not hygroscopic (doesn't absorb water, so any fluid in your system will just stay as water, which means it will boil when you heat up the brakes), and if your system is not completely flushed prior to adding the DOT 5 stuff it will gum everything up.
At the last open track event I went to last fall I talked to a guy who hadn't been told all of the above. He added DOT 5 to his system, and it gummed everything up so bad he had to overhaul all 4 calipers and get a new master cylinder. Yikes!! DOT 5 is good for race cars, where the fluid will be swapped out so frequently that moisture in the system won't be a problem. For street cars, it's a no-no.
Now, if it is DOT 5.1, then you're fine. I'm not sure why the DOT didn't call DOT 5.1 "DOT 6", but they didn't. DOT 5.1 is synthetic brake fluid, but is completely compatible with DOT 3 and 4.
Anyway, for fluid recommendations, ATE Super Blue and Motul 600 are probably the way to go. I've got a Valvoline Synthetic fluid in my car now, but it hasn't been tested on the track yet. The dry and wet boiling points both look good (the wet in particular), so hopefully it holds up as well as the numbers would make it seem.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 01-24-2001, 07:02 AM   #6
lucien2
Member#: 1519
1998 Volvo V70R
Thumbs up
Thanks for the heads up. His web site lists it as Motul 600 Dot 4, so I suppose this is in fact what I'm getting.
Super Blue is what my friend reccommended; said it was cheaper than Motul. Hopefully, I'll get this stuff in the next couple days...
Old 01-24-2001, 11:28 AM   #7
lucien2
Member#: 1519
1998 Volvo V70R
Thumbs up
It's Motul 600 DOT 4. I'm in the clear!
Old 01-24-2001, 07:23 PM   #8
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
The biggest bang for buck brake mod is SS brake lines, if you haven't already.
gavin is offline   Reply With Quote
Old 01-25-2001, 12:32 AM   #9
Jgrahn555
Member#: 3224
Post
ATE SuperBlue Racing. Good stuff. Worth the buy. got it from Bap/Geon in Tacoma.
Jgrahn555 is offline   Reply With Quote
POLL: what's everyones using for enginemanagment WRXout Engine Management & Tuning 20 08-09-2005 12:42 PM
What's everyone doing for New Years? codemunky Southern California Impreza Club Forum -- SCIC 21 01-01-2002 11:08 PM
What's everyone doing for New Years? Philly WReX Tri-State Area Forum 7 12-28-2001 03:54 PM
What's everyone using for detailing? 02 T-WREX Car Care & Detailing 54 12-13-2001 09:59 AM
what's everyone doing for new years? chuckles New England Impreza Club Forum -- NESIC 64 12-12-2001 04:56 AM
