Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-06-2006, 10:28 PM   #1
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Default 2 autox questions: Tires sizes/heat and alignment
Ok two questions...first regarding alignment.
I have heard from various sources that I should get camber bolts in the rear to bring the camber back to around -1.5 (currently at about -2). Front camber is maxed out at -1.8. This decision would ultimately sacrifice total grip for a slightly more oversteer prone car, right? Do you think it would be worth it to make that comprimise?
Also...at this weekend's autox I had what was either a breakthrough in my driving or just a super lucky weekend. I finished 2nd in STU by about .3 secs and beat a few guys that usually beat me by around 2 seconds on a 50 second course. The course this weekend was unusually short, about 34 seconds. Could it be that the bigger tires on most of my competition were not warming up enough (most were Evos running 245/45s, I run 235/40s) and therefore not producing the grip they are used to getting?
Just a thought.
waktasz is offline   Reply With Quote
Old 06-06-2006, 10:51 PM   #2
leecea
Member#: 37359
2003 WRX
Looking at your location, I wonder if the short course was at Boeing and the longer ones at Ripken or Warminster. If so, I think the differences in speed and tightness of the course are a bigger factor than tire temps. Even so, beating people who are usually that much faster is grounds for celebration
leecea is offline   Reply With Quote
Old 06-06-2006, 11:19 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
If you want to dial out additional oversteer and you absolutely can't get more front neg camber (that is the more desired way)- then yes dial some positive camber into the rear. Everyone is different, but I prefer a ~ .8 difference front to rear. thus in your case I'd dial down to about -1.0 (I wouldn't go any lower than -1.0 though).
My guess is heat in the tires was not a factor- I'd chalk up to good driving
Old 06-06-2006, 11:31 PM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
You are correct sir.
Old 06-06-2006, 11:41 PM   #5
tuskenraider
Member#: 65699
15 WRX
WR Blue
Most of the top autox tires don't need much heat, if any, for optimum performance. Still, it's brand dependant and even so, the small difference in size is undoubtedly irrelevant.
tuskenraider is offline   Reply With Quote
08 Impreza 2.5i 4dr tire size gingburg Tire & Wheel 7 06-13-2009 02:00 PM
Tire size limit and icing the I/C? adadaead Newbies & FAQs 5 04-08-2008 04:20 PM
AutoX DS tire size MFR Sweep Tire & Wheel 2 08-02-2006 03:52 PM
tire mounting/balancing and alignment in glendale rawrFERNY Southern California Impreza Club Forum -- SCIC 0 09-11-2004 03:54 PM
Good 16" AutoX/Street tire size for Wagon guinsu Brakes, Steering & Suspension 1 06-10-2002 05:00 PM
