Old 06-07-2006, 12:12 AM   #1
irishhockeypimp
Member#: 85263
1999 Impreza W-RS-X
Default will an 05 sti front sway bar work on an 02 wrx crossmember?
just as the title says.....i had an 05 sti front sway bar given to me and i have an 02 wrx swap in my 99rs.....will it work on my car? I am a newb when it comes to suspension.
irishhockeypimp is offline   Reply With Quote
Old 06-07-2006, 09:00 AM   #2
subieworx
Member#: 47769
Not sure exactly, but the 05 sti front bar will work on an 02 wrx. They should be the same, not sure if they changed the width or not, but it will work.
subieworx is offline   Reply With Quote
Old 06-07-2006, 09:23 AM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Hmm... that's a tricky one... you have a turbo crossmember but 'GC' control arms and track? The fitment of the bar to the crossmember should be OK - but there maybe issues with the bar's length and hence the endlink fitment/angle... you might do better with a GG turbo wagon bar...?
I'm only speculating - likely someone in the 'Conversions' forum will know for sure. This thread explains some of the differences.
UkNuck is offline   Reply With Quote
Old 06-07-2006, 10:46 AM   #4
irishhockeypimp
Member#: 85263
1999 Impreza W-RS-X
actually the crossmember came out of a 02 wrx wagon so the control arms are from a turbo model.....
Old 06-07-2006, 10:47 AM   #5
subieworx
Member#: 47769
Then you should be fine.
Old 06-07-2006, 10:53 AM   #6
irishhockeypimp
Member#: 85263
1999 Impreza W-RS-X
absolutely wonderful....now another question not sure if you guys will know....it came with the bushings but since it's an STI bar i wasn't sure if the mounts for the bushings would work off my wrx ones....do i need to get STI ones to fit over the bushings? and if so where do i find them?
Is an 04 USDM STI front sway bar identical to an 04 WRX sedan front sway bar? legacy2003 Brakes, Steering & Suspension 1 10-01-2009 05:25 PM
Front Sway Bar Fitment on an 05 RS (autox) formula91 Brakes, Steering & Suspension 0 03-28-2009 11:42 PM
FS: 05 STI front sway bar and endlinks rougeben83 Suspension/Brakes/Handling 5 08-07-2008 06:23 PM
05 sti front sway bar on 05 2.5rs? oatmealman Newbies & FAQs 3 11-02-2007 10:30 AM
What 20mm rear sway bar works on an 05 RS? sc00ter Brakes, Steering & Suspension 3 01-23-2007 07:26 PM
