Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-13-2001, 11:05 PM   #1
Sobelizard109
Member#: 10302
2005 GT WAGON
SILVER
Question Oil Additive?
I was reading about "restore" in car an driver. It is an additive that you add to your oil an it claims to restore an improve compression, etc.... to your car. I have a 88 subaru GL wagon an was wondering if anyone has used this product before? Any input appreciated, thanks
Sobelizard109 is offline   Reply With Quote
Old 10-14-2001, 12:20 AM   #2
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I would personaly go with thicker grade of oil (Synthetic preferebly) and a fuel system cleaner.
I don't like additives as they always have a side effect.
The other option is to go to a dealer or quick lube places and get the engine flushed with the Bilstein Engine Cleaning Machine. It works wonders.
Good Luck,
Leo
Leonardo is offline   Reply With Quote
Old 10-16-2001, 07:30 PM   #3
MrHorspwer
Member#: 4063
I have used the engine restorer... it did help. Mind you it helped a 1981 Firebird with a 3.8 V6 that the cylinder walls were so washed down and there was so much blow-by that the oil would be so diluted with gasoline after 1000 miles, it would not have any oil pressure at idle(it would go around 2000 miles after the restorer). I really wish I had taken a compression test or done a leakdown test before and after... it was bad. In this extreme case... it worked. In a normal, well maintained vehicle... I doubt it. I would advise you to stay away from synthetics if it is a higer milage vehicle... unless you like replacing all the seals that will begin leaking after the switch to synthetic(unless you have been using it all along... in which case you can disregard what I just said). Whatever you do... DON'T use any additive with teflon. Teflon is about the right size for your oil filter to pick it up... and clog it up. Think about this too. Ads claim teflon bonds to berings and wear areas... much like a superimproved extreme pressure additive that is in all oils. Teflon is sprayed on frying pans, the ones you can't use metal utensiles one because it scratches the teflon. If teflon is sprayed onto a clean pan in a manufacturing plant under strict conditions and still can't have metal touch it because it scratches off... how is it supposted to protect a dirty, oily bearing just by contact?
MrHorspwer is offline   Reply With Quote
Old 10-18-2001, 02:10 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Do or have done a compression check, if it is within specs I would'nt bother with the "magic additives". If it's not within specs then you need to determine what the problem is. Blowby means your piston rings or cylinder walls are worn and usually shows up as blue smoke during cold starts. this would require either a rebuild or replacement of the engine. I did'nt catch your miles on your post, did you post that?
Are you having trouble with your engine? Or are you just asking?
Tim Sanderson is offline   Reply With Quote
Old 10-19-2001, 03:37 PM   #5
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
To me, oil additive is just a bandage to the underlying problem and may cause even more problems. It is best if you get to the root of the problem instead of covering it up.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 10-19-2001, 06:26 PM   #6
Sobelizard109
Member#: 10302
2005 GT WAGON
SILVER
Its a 1988 GL wagon with 175698 miles
What do you all think about oil additives like Z-max and other various products? Jasno999 Service & Maintenance 64 11-11-2008 09:58 AM
Engine oil additive....what is good? jobs Engine Management & Tuning 7 05-04-2004 06:29 PM
Any have any experience with MILITEC-1, a metal strengthener and oil additive? fengshui-fu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-12-2003 01:52 PM
('93-'01) what is BG motor oil additive? 15K service manifest says they add it but i run synth nkodemus82 Impreza Forum 6 04-23-2001 10:37 AM
Prolong??? Oil Additive STORER Normally Aspirated Powertrain 9 12-15-2000 07:45 PM
