Old 06-07-2006, 06:00 AM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default Going to install mods what else do I need?
I will do some research later but am too busy right now at work. What I have going on is: Installing VF22 w/Deadbolt treatment, JDM pinks, Walbro FP, Omori gauges(boost and EGT). I want to get new o rings for inj.(bought used), and would like to get new gaskets but not sure all the ones I need. What else should I replace or do I need to perform this install. And yes I will be ordering some PDX maps for tuning for the AP. Any tips would be appretiated.
breathinez is offline   Reply With Quote
Old 06-07-2006, 11:22 AM   #2
r0n
Member#: 91839
a bigger intercooler, the vf 22 is the biggest turbo of the vf series, ive seen over 300 whp with it. I would have gone bigger than pinks, and i'd either geta big TMIC or a FMIC.
r0n is offline   Reply With Quote
Old 06-07-2006, 02:13 PM   #3
benw
Member#: 103320
1998 swapped
Forester L
fuel pump should come with its own install parts. Just need the new clip to hold the sock on. fuel injector o-rings can be sourced from mcmaster carr or at your subaru dealer, or you can use the rings from your stock injectors when you pull them out. You will need 2 gaskets for the turbo: downpipe to turbo and uppipe to turbo. Should run you 35 bucks or so for both of those.
Your pinks will be around 90% duty with the 22 so be careful
benw is offline   Reply With Quote
Old 06-08-2006, 12:16 PM   #4
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Okay I will get those gaskets and probably the new orings just to be safe. If I go with the PDX maps could I use the GM solonoid, that I have read about. I understand you would have to tune for the new boost controler but was wondering if PDX could do that in the map or would it have to be tuned on a dyno? Oh yeah I will definitly need new spark plugs. One step colder NGK coppers. Not sure the part number though. I will look it up but if anyone has it handy that would be great. Thanks
Old 06-08-2006, 04:00 PM   #5
enash99
Member#: 72363
03 WRX VF-34
Could always whack off the caps on the stock wrx injectors. Not that i am recommending it. But i would want 700+ cc injectors for vf22..
enash99 is offline   Reply With Quote
Old 06-08-2006, 08:05 PM   #6
benw
Member#: 103320
1998 swapped
Forester L
565 is ok, 650 would be perfect.
www.deatschwerks.com has great prices and I've seen their shop in person, it's a good alternative to high priced injectors.
Old 06-08-2006, 09:41 PM   #7
dibblejr
Member#: 94070
05 LGT
My VF22 setup = Pinks, Walbro, $145 Ebay Dynasty Auto TMIC, Agency Power Pulley, Oil CC, Perrin UP, PDE DP, Meagan CB.
When you do the install= New O-Rings, PM me your addy I will send you some. New UP upper gasket, new DP Upper Gasket, Coolant. If you get $145 TMIC new TMIC gaskets, "Y" pipe ( perrin, Samco) use the " Y" pipe mounts from your stock TMIC everything except pax side mount lines up.
Like I said pm me your address I will send you some o-rings.
Dont forget you will need a retune before you get into boost with the new setup. If you have EM I have a base map that will get you by until the Pro Tune/ re-tune.
dibblejr is offline   Reply With Quote
Old 06-09-2006, 11:40 AM   #8
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Hey Dibblejr, I appretiate that. I'm going to use the pinks and I do have one of the ebay(SSautochrome) tmic. I was thinking of the PDX maps but if you have a base map I can run so I could go and get a real tune that would be even better. I'll pm you my addy. And thanks alot.
Finally decided to go with the Blouch 18G, what else do I need to get? lateralus1082 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 03-24-2009 06:49 PM
just ordered some STi heads to go wiith my EJ257 block...what else do I need? ted dibiase Built Motor Discussion 10 10-04-2007 01:40 PM
Installing a vf23, what else do i need? druxboyz Newbies & FAQs 3 10-02-2006 07:05 AM
VF-39 install. what else do i need? HEAVY.HITTIN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-17-2006 04:42 AM
What else do I need to consider before installing this GenMaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-21-2003 11:11 PM
